Wd45 valve cover torque specs
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 valve cover torque specs
    Posted: 25 Apr 2012 at 9:06pm
Hey guys what are the torque Specs for the valve cover nuts ? I think there way over tightened thanks -justin
Edited by Allis-chalmers wd45 - 25 Apr 2012 at 10:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 10:01pm
Would his contribute to it smoking?
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:29am
I doubt it. Just snug them up. Use sealer on the gasket to stop any leakage. If it leaks, tighten up a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:35am
If it has been over-tightened, it probably needs hammered out. They bend quite easily and get distorted so the gasket doesn't seal properly. Take it off and use a straight edge to see how bent up it is. A nut drive will get the bolts tight enough without using a ratchet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:36am
Yes, if oil is leaking out from the gasket and running down on the manifold. It has nothing to do with burned oil coming out of the exhaust.
