8010 Hard Shifting
Dave in Oregon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in Oregon Quote  Post ReplyReply Direct Link To This Post Topic: 8010 Hard Shifting
    Posted: 25 Apr 2012 at 9:50am
On my 8010 with power shift, the range shift Hi-Low is extremely hard to shift most of the time.  I took the cable loose from the shift lever on transmission to see if the cable then  moved free.  It moved extremely easily.  My question is, could it still be the cable binding when under load?  Or could it be something else?
Any help appreciated.
Thanks,
Dave
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 1:16pm
Have you ever replaced to cable? when they get old they are hard to shift. Replace it and you should be good.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 4:38pm
When you are in gear, is there any sign of creeping???  A slightly warped PD or main clutch would cause hard shifting.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
pump grump View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote pump grump Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 9:19pm
Hi Dave, you get your trees out yet ??  Or too much rain ?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 9:35pm
Most often,it's the cable.The 8000 series was introduced in 1982,that's 30 years ago.Time has a way of wearing on things like that.You might check how it shifts when it's running,or when it' shut off.If no difference,then I would certainly suspect the cable.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2012 at 9:38pm
I have found on my 8030 there is a little drag, if I shift to reverse the range shift is easier, not the handiest thing but it solves my problem of hard range shift.
MI8050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI8050 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 3:58am
I do this too, mine has the forward creep to it, a quick reverse shift then back to neutral will make an easy shift to high, low, or park.
