D-19 rear hub removal tricks???
tomstile View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstile Quote  Post ReplyReply Direct Link To This Post Topic: D-19 rear hub removal tricks???
    Posted: 22 Apr 2012 at 3:29pm
I need to remove the rear wheels so I need to know the trick to the hubs. I do not have the special removal bolts that I have seen in the manual. Any help would be much appreciated.
ChuckLuedtkeSEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 3:47pm
Well, you need the bolts to get them apart.   Basically, the bolts have an unthreaded portion on the front of them so they thread into the center part of the hub and push against the outer portion of the hub.   You thread each one in till it's tight and then put some pressure on each one and work your way around and the center portion will pop away from the outer part.   I only have two factory ones, and that wasn't enough to get them loose, but a local friend had three of them that his son made in high school, and after using three of them they popped loose really easy.
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2012 at 3:53pm
Never tried to remove the hubs with out the special bolts. Usually i tighten the bolts up with my 1/2 impact then we have a big gear puller i put on the tapered wedge assy and then beat on the cast iron hub center with the big sledge hammer for a while then go through tightening the bolts a little more with the impact as well as the puller. Clean the rust and paint off the axle too and penetraiting oil wont hurt anything. If you cant come up with any of the special bolts im sure a machine shop could probably modify some standard bolts for you to use. Good luck!!
This page was generated in 0.048 seconds.
