d17 injectors
donais View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Topic: d17 injectors
    Posted: 17 Jan 2012 at 8:15pm
on the d17 s.3 diesel  i took out one injector it has 3 copper washers on it the book says replace THE washer when removed.... should there ever be 3 on there? or should i make sure there is only one...thanks jon
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 8:16pm
1only
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 8:18pm
i guess i get to check them all now.. no clearance problems?   and might it run a little  better?
ChuckLuedtkeSEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 8:18pm
On my 45 diesel, there is only one washer per injector.   I don't know why there would be three on one of them; did all three fit on the end of the tip?   I would think that if it was past the end of the tip, it would have a hard time getting that to seal.     I would pull the other injectors as well and see how many are on each one.   Unless someone put new washers on twice and never removed the old ones.   They can be stubborn to get out sometimes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 8:29pm
about a quarter inch hanging out of the end on the first one... im thinking the old ones got all carbony and they just put new ones on
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 1:27pm
i think i know why the injectors have 3 washers.. they might not be the right ones.  The injectors in there are # 4511207 on the body and 4511205 on the part that goes in the hole. what is the right # posta be?  i measured the inside and it is .310, the injector  tip is about a half inch long. with the three washers it is just about .310 . on another note where is the hole and timing pin in the flywheel  the front pully doesnt have any marks?
thanks  jon
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 8:53pm
Left side of the engine in front of the bell housing about the hieght of the frame rail is a shoulder bolt. Unscrew this bolt and invert it and insert it into the mating hole in the flywheel. You'll have to rotate the engine onto compresion stroke by removing the cover on the side of the injector pump and watch the window for the timing mark on the rotating group to line up with the static mark. You may have to rock the crank slightly away from the marks perfect alignment as this indicates how much advance your pump timing has. When the bolt falls into the flywheel you are TDC. Don't forget to remove the bolt before attempting to start. I have seen bent shoulders on bolts before.lol
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 10:07pm
thanks dave ill try that tomorrow . any insite on the injectors?   so last week i changed the oil, air filter and fuel filters, now the stupid thing has some blowby.  i guess the crude oil in the crankcase was sealing it up pretty good. would seafoam maybe clean up the inside of the motor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:46am
As old as the engine is I would exspect some blowby. Every engine has some so unless you want to get real technical and measure it with a monameter don't worry about it. As for cleaning it out there are any number of aditives and home made concoctions that could help clean out an engine. The thing is that if you do have  some type of crud internally and you break it loose then where is it likely to go. It could end up somewhere it doesn't need to be. IMHO the only thing I would do is solve the injector issue and run it good under load for a few hrs. Work the engine and get it good and hot naturally. Keep an eye on the oil for contamination and repeat an oil change if you see it getting contaminated soon. You don't know what has been changed on the engine prior to you so if there is a compatibility issue I'm sure several may have an extra set of injectors that you can get and have them serviced before installing them. This way you know what you have.
This page was generated in 0.058 seconds.
