Looking for a brake riveter
ChuckLuedtkeSEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Looking for a brake riveter
    Posted: 07 Jan 2012 at 10:08pm
Where have you guys bought your brake riveters.   Would like to find one that mounts in the vice and you either drive them with a hammer, or screw down type.   American made would be the best, if available.   I have used a punch and did them by hand before, but I always love to have the right tool for the job.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 10:12pm
Don't know if it's american made or not, but seems like there is always one on ebay, it is it own setup, no vice needed, but would probably work best on an anvil, or some other large mass, as it doesn't have much to it.
Went to find a link for you, and didn't see one, but there are many if you look at just brake rivet tool
Still in use:
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 10:22pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2012 at 11:31pm
i got mine from STINER
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 5:16am
Out of stock right now......should have some middle of the month, mad rush for them prior to Christmas.   www.djstractorparts.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
RickinNH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickinNH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 6:39am
I bought this one because Steiner was out of stock.
http://www.aircraftspruce.com/menus/to/rivet_brake.html
Didn't like it. The opening is too narrow to get WD45 shoes into and be square with the pins. Could be just me. Not a mechanic. Maybe why there are 6 AC tractors here and only 2 barely run.
MBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 8:32am
Any Model A Ford restoration parts source has them. Try Old Time Auto at Lake Mills.
Warren(Oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 8:38am
I used a Pony leather riveter  for my G brakes. Had to make a little button to mash into the hole but it worked. I have a regular stand up rivet tool now, foot operated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 9:32am
depending on how heavy you want to get into doing linings, check with some truck shops either to use theirs or see if they have one for sale, many buy just bonded linings now and seldom rivet shoes any more.
 A small arbor press should work better than a punch and hammer in a vice also.
lockheedt33 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lockheedt33 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 9:53am
I'm an aircraft mechanic and always use our brake riveting tools for the little airplanes to rivet my allis linings.  If your looking for a easy tool check www.aircraft-tools.com I have their W403 riveter that I use all the time it's only $12.95 on sale now.  That tool you clamp in the vise to hold it and it has a punch to remove the rivet and another one to set the new rivets both of which you hit with a hammer.  They also have their W404 tool that has a threaded press action so you can use it hand held and don't need the vise.  The hammer style takes a little bit to get used to because you have to hold the lining and backer together with the rivet in place while you hit it with the hammer but it's really fast.  You can reline both sides of the brake band in less than five minutes.  The screw style is a little slower but works good too.
1941 AC B
1948 AC C
1951 AC CA
1954 AC WD45
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 10:01am
RickinNH,
Did you get the punch style or the screw type?
The screw type looks like it has more space to work with.
Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickinNH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 10:13am
I bought the punch type. I didn't see the screw type until today.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 10:38am
I have the deluxe model from Aircraft Tool Supply. It costs about a buck more than the regular one. has grove in the bottom edege to clamp in the vise, and a screw pin and set. works great. I bought form doing brakes on my airplane but works for tractor brakes also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 10:55am
Lockheed,
I reread your post and went to that site; lots of interesting stuff there.
I ordered the "screw-type" riveter which was on sale for $21.95.
I have ordered the special bearings used in the A-C "Twin-Wheel" mowers from "Aircraft Spruce", so now I'm doing business with two aircraft tool and equipment suppliers and I don't know a thing about aircraft.  LOL
Thanks for the tip!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2012 at 2:30pm
Seems like I've seen them at Valu-Bilt. I just set all the rivets on my D17 with a hammer and a couple drift punches. You just have to be careful to not over do it.
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2012 at 7:36am
Ask around at old timer bus or truck garages. I was given a floor model with tooling because they no longer needed it. If I had not taken it, it was headed for the trash. It ,may look like an antique, but works like a champ.
