Duals on a 185 |
Central WI AC guy ![]() Bronze Level ![]() Joined: 20 Dec 2010 Points: 14 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Dec 2011 at 2:47pm |
Hi all! I have a 185 with 16.9-38s on it that I want to put duals on. It has the old style spin out clamps like a wd would have not the newer style like my 200 has, and I am wondering what/where I should attach the ring to where the clamp hooks up or if they make a special bracket for that type of spin out clamp. Thank you in advance, Jim
Russ-neia ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: NE Iowa Points: 489 |
There are special brackets that clamp to the inside of the power-adjust rail. There are two types; one is cast and has an eye for a J-bolt to hook into. The other is more of a clip that sits inside the rail and keeps the hook seated to the rail. Both styles work well and should be able to find used ones easily.
These are new ones from Unverferth (Brent Wagons).
The innovators offer what others will imitate.
ILGLEANER ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
Just take the nuts off where your pieces attach the wheel to the rims. And put an eyebolt in place of the nuts. And attach your clamps there. That is how all the clamp on duals are around here.
IG
