hydrolic pump alice B
keith ashley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keith ashley Quote  Post ReplyReply Direct Link To This Post Topic: hydrolic pump alice B
    Posted: 25 Nov 2011 at 5:21pm
Hi Guys have done a pressure test on the allice b pump it pushing a 1000 psi just over, even when engine on full rev it never fluctuates i thought we had solved the problem ?? am right in assuming it should be 3000 psi is that right?  if so am asking for advice again? plus can any one tell me were this number is from or what it stands for as this is the engine no R10644k keith.
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 5:26pm
At least you spelled pump right...
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 5:26pm
Yep, you have a problem.  Should see at least 2500, and 3000 (might be 3200) is spec.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 6:44pm
Hey powertech, before you embarass yourself, not all Allis tractors are in the US.
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 6:58pm
Thanks jim, feel better now?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 7:06pm
As far as your serial # the R prefix was used on RC tractors and power unit motors and the K is for Kerosene.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 7:17pm
To get more pressure take plug out of top of pump and loosen set screw on side then punch sleeve down on relieve spring . Just a little does a lot.
