D17 rear end Oil
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: D17 rear end Oil
    Posted: 29 Jul 2011 at 6:01am
Series II
I drained the old oil out and need to know what I need to get to replace it.
Manual just says 24 quarts Special Allis-Chalmers Oil
Charlie
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 6:11am
              80/90 wt. oil in the rear end.
                               John Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 6:41am
thanks!
Charlie
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2011 at 7:18am
Hyd. wet brake oil.  agco 821 JD 303  IH Hi tran or any good brand. Much better than the old type of oils.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2011 at 4:13pm
Mack, are you using the same oil for the hydraulic and power director?
Charlie
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2011 at 8:36am
Yes use the same oil all the way through. No reason not to use it in final drives also. All the newer tractors use it in final drives (planitary now) on most.   MACK
This page was generated in 0.140 seconds.
