|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| D17IV/170/180 3ph Drawbar Question |
| Post Reply   |
| rhartwick   Bronze Level   Joined: 10 Apr 2011 Location: NY Points: 41 |  Post Options  Thanks(0)  Quote  Reply  Topic: D17IV/170/180 3ph Drawbar Question Posted: 28 Apr 2011 at 3:40pm |
   Hey everyone, thanks for all of the collective help I've gotten in getting a factory 3ph from a salvaged 180 onto my late model D17 IV.  The 3ph assembly bolted on perfectly.  Unfortunately, I did not get the factory 3ph drawbar when I picked up the other parts from the salvage yard. They had it available, but I wasn't sure what else I would need to change to mount it on my IV. It was a long, straight thing - not bolted up, and it didn't appear to have a SnapCoupler loop on the front. I have been unable to see the parts drawings on the AGCO website. I basically need to swap out the Snap Coupler housing, held by 6 large bolts, to whatever assembly would bolt onto the IV to accept the drawbar. The salvage yard is quite a ways away, and I won't have time to just drive out there and look at the actual 180 donor. So the short question is - is there a housing on the 180 that I can have them pull, that would bolt onto my IV to accept the 3 ph straight drawbar? Do I have to do any further internal modifications to my IV to change out the SnapCoupler housing? I have to say, the factory 3ph brackets and assembly seem to be built like a bulldog. They didn't have the sway blocks, but I will keep looking for a set of those. Meanwhile, I am thinking some tough old oak hunks should do the trick, at least for a while. | |
| DMiller   Orange Level Access   Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34340 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Apr 2011 at 4:15pm |
   This is the connective point on my 180, old picture and doesn't show the whole mount sorry.  | |
| DMiller   Orange Level Access   Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34340 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Apr 2011 at 4:16pm |
   You may be able to weld up a similar bracket to replace the SC eye assembly.
| Skyhighballoon(MO)   Orange Level     Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Apr 2011 at 4:21pm |
   I don't have a good picture of my 180 to show this.  The drawbar is not straight, it has an "upward" dogleg going from rear to front.  There is a bracket that bolts up near where the SC bell used to be that the front of the drawbar slides through.  There is a pin that goes through the drawbar to anchor it and there are two positions, regular and forward I believe, to set how far it extends out the back.
     1981 Gleaner F2 Corn Plus w 13' flex 1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers | |
| Skyhighballoon(MO)   Orange Level     Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Apr 2011 at 4:22pm |
   Dave - great pic to show what I was trying to say....  :-)   Mike
| rhartwick   Bronze Level   Joined: 10 Apr 2011 Location: NY Points: 41 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Apr 2011 at 5:25pm |
   Dave and Shyhigh,  Thanks! Dave - great picture. It is odd - but the drawbar the salvage yard showed me lying on the floor was definitely straight and flat - and couldn't have come off a 180. Good thing I didn't just buy it. I am going to need to dig into this a bit further before buying anything. From the picture, it appears that the brake peddle mounts would be different - at least on a 180 vs my IV. So perhaps a custom welding job to my old SC drawbar might be a better approach. Oddly enough, on my IV, the SC is in an almost straight line back through the drawbar roller support on the new 3 ph assembly. Not sure if the factory setup on my IV would be the same details as the 180 - even though the basic housing might be the same. If I could get the AGCO site to work, I could compare the drawings for the IV vs a 180, but it keeps demanding some new viewer that I can't get to load or run on my computer. | |
| Orange Blood   Orange Level     Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Apr 2011 at 5:43pm |
   Just looking at that picture vs. my 17 series III, the brake pivot shaft looks to be mounted the same way as the one in the picture, it also runs through the snap coupler mounting bracket.  I bet it is very similar.  My guess is, if you pull off your brake shaft, unbolt the sc from the bottom of the transmission, the bolt up the drawbar mount, re-install the brake shaft pivot, you will have exactly what you need.
     Still in use: HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 | |
| Russ-neia   Silver Level   Joined: 11 Sep 2009 Location: NE Iowa Points: 489 |  Post Options  Thanks(0)  Quote  Reply  Posted: 28 Apr 2011 at 9:26pm |
   The 180 and Series IV drawbar mount are the same.   Both hold the brake pedals.
     The innovators offer what others will imitate.
| Eldon (WA)   Orange Level     Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |  Post Options  Thanks(0)  Quote  Reply  Posted: 29 Apr 2011 at 12:26am |
   My 170D drawbar is still floating out there in FedEx land somewhere......
     ALLIS EXPRESS! This year: | |
| rhartwick   Bronze Level   Joined: 10 Apr 2011 Location: NY Points: 41 |  Post Options  Thanks(0)  Quote  Reply  Posted: 29 Apr 2011 at 6:45am |
   Thanks guys,  You're right. I wasn't looking at my IV when I said that, and my memory wasn't working too well. So let me call the junkyard and see if they can pull the housing. I've also got to sort out with them what drawbar they had lying on the floor - but it wasn't from a 180 based on these pictures. | |
| Central WI AC guy   Bronze Level   Joined: 20 Dec 2010 Points: 14 |  Post Options  Thanks(0)  Quote  Reply  Posted: 29 Apr 2011 at 1:36pm |
| DMiller   Orange Level Access   Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34340 |  Post Options  Thanks(0)  Quote  Reply  Posted: 29 Apr 2011 at 7:17pm |
   By the enlarged look this one has the same issues mine had, that is now repaired; see my post on drawbar 180.
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
