A-C model # 7 trail mower
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Topic: A-C model # 7 trail mower
    Posted: 18 Apr 2011 at 6:06am
i have used cycle bar mowers most of my life, mostly a ford,new holland or a international, and anymore i just use them to cut up under trees and fences and such.
but there is a allis trail type mower near by,that the seller says is a model number seven, it is one with small rubber tires. it has a A-C cylinder
anyone here ever have any dealings with one of these mowing machines, are there anything that i would need to look for that is peculiar to this model, that i would need to look for.
i am thinking that i would like a trail type mower, so i could just drop in a pin, rather than wrestle the old ford 515 that i have now
Edited by ky wonder - 18 Apr 2011 at 6:18am
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 6:33am
I have one,just check out the bearings on the connecting rods for the sickle bar. And I also had to replace the bearing at the large pully. If everything is tight they are a very quiet machine. There sales pitch was that it's so quiet you can hear the grass fall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:59am
thanks!!! ,
do you know what era/dates  where these built do you know?
Edited by ky wonder - 18 Apr 2011 at 10:01am
LloydCentWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LloydCentWi Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 10:05am
We used one of the No. 7 mowers for several years in the 70's, until the twin disc shafts snapped off by the flywheels. As I remember we had problems with the gear box leaking fluid. I know dad had replaced the seals at least once, but everything might have been worn too badly before we got it. I picked up another one about 5 years ago but haven't used it yet. Around the same time I picked up a newer model with large tires and have used that one quite a few times and it does a good job. You have to do some daily maint with these. Check the fluid level in the gear box regularly and make sure nothing is run loose very long or it'll shake itself apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 11:00pm
thanks
This page was generated in 0.038 seconds.
