More wc front pedistal questions?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: More wc front pedistal questions?
    Posted: 25 Mar 2011 at 8:50pm
I was given another pedistal with a broken housing. I need to remove the big (verticle shaft). Can I pull it out through the top with the gear still on it? I tried to remove the gear on my old one and couldn't get the gear off. I destroyed a 3 armed china junk puller in the process. I need the big shaft to go in my original housing since the new housing is busted and has several broke bolts in it. Can I get the cork seal on the bottom of the big shaft at agco? It's the seal that goes on the spindle block. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:04pm
Yes, if you remove the spindle shaft from the bottom, it should come apart.
I don't know if AGCO has them  but I bought one through work. Probably Chicago Rawhide or National. It is not the cork, but a rubber lip seal. I did away with gear oil in my front end by packing the bearings with grease.
Edited by CTuckerNWIL - 26 Mar 2011 at 8:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:11pm
Thanks Charley I'll try again. I do have the set screw removed. I haven't tried the gear removal on the new pedistal yet. Do you use a 3 jaw puller?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:24pm
If you have the setscrew removed completely. support the casting so you can drive the shaft down with a brass or lead hammer or any chunk of brass you can pound on.
I can not get a picture to upload from my hard drive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2011 at 9:28pm
If you open this MS photo editor you can blow it up to 150% and see all the internals.
After looking at it some more, I wonder about the shoulder that the bottom thrust bearing sits on. Maybe it will separate from the vertical shaft with the spindle shaft removed.
Edited by CTuckerNWIL - 25 Mar 2011 at 9:35pm
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 4:20am
On my unstyled WC, I took the spindles off and lifted the shaft and gear out the top.
Got the cork seal from Brenda, at Sandy Lake Imp.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 7:25am
I just rebuilt the front end on a WD-45, and got all the bearings and seals needed from AGCO.  And yes you can pull the big shaft out from the top.  You just have to turn it correctly, and the set screw should be pointing at one of the corners and it will come right out.  You will have to remove the two 5/8 bolts that hold the shaft with the worm gear on it to get it out of the way so you can pull the big shaft out.  I am guessing you allready removed the crank start shaft from the housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 8:29pm
Thanks for all the help guys. I got some time in the shop yesterday and got both pedistals took apart. My pedistal had good bearings and tight steering but the keyway on the big shaft was shot. I took the shaft out of the new one and the spindle block and cleaned and assembled it all back. I had to make a shim spacer to get the bearing space right and now it works perfect. I need to order the seals and install them and I should be good to go. It feels good to get  progress in the right direction.
