Back row kids...( Ugly Tractors ) |
Page 12> |
Eddie(IL) ![]() Orange Level ![]() Joined: 25 Apr 2010 Location: Oakwood, IL Points: 385 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Mar 2011 at 9:50am |
How about a tribute to those poor old back row tractors, that never got their chance
in front of the paint gun, but would still give you a full days work if given the chance!
This one is a good starter...if you look closely, it's a 45 diesel with p/steering that we stumbled on to here locally. It had a wood bench seat in the cab, and even a heater.
The other is a little Ford 8N with the Funk mfg. 6cyl. conversion, we found a while back. Eddie
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
man! they did alot of work...for a trip bucket loader tractor!! i'd take it! them little ford tractors look cute, but they have killed alot of people! everyone should have taken a class before operating them!
Shameless, That is an 8N, I didn't know they caused a lot of deaths. The old Fordsons had a reputation of going over backwards but that was because of the geometry of the hitch point. I still hear people talk about the "dang worm drive making it tip up" but any differential can do that if you hitch too high and behind the axle.
Eddie, I think my 45 is in that class.
split51 ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Guthrie, OK Points: 713 |
Tucker, I think shameless was refering to the PTO with attachments like a mower pushing people through fences and over ravines.
1929 20-35 sn17662
B1 w/snow blade B10 w/sickle mower B110 w/mower deck B110 w/tiller B112 w/grader blade B210 w/plo |
HagerAC ![]() Orange Level ![]() ![]() Joined: 14 Sep 2010 Location: SE MN Points: 1195 |
Here is a pic of our D-19 gas. It served my uncle well as a loader tractor for probably 20-25 years with very little trouble. It has since been retired but we still use it around our place some. Hope to get it restored someday, but its gonna be a lot of work.
Never give up hope on anything...and always think ahead, even though it may seem like you'll never get there. Here's a before and after of this 1962 D19 we restored...
This is ugly!
It was easy with the Ford N series to hitch a hard pull to the three point links that would rise and raise the pulling point to tip it over backwards. If it had an optional draw bar on the bottom of the axle that and it was used it was harder to tip if over backwards. It was often tempting to run a chain around the axle when pulling a stump and that was deadly. A neighbor rented a Ford, probably later than an 8N with a brush hog and hooked it on a stump. It smashed him against the mower hitch. He didn's survive but the tractor wasn't even scratched.
Using a 3 point hitch on an Allis the same will make it tip the same way. Hitching a chain around the axle will tip the Allis faster than the Ford. The PTO was very easily solved with the SAME overruning clutch that nearly every other tractor of that era needed on the PTO. The N series was just way too light for real work. Gerald J. |
Dave Richards (WV) ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fairmont, WV Points: 881 |
I have been known to hook a chain to about every part of a tractor. Favorite is front axle on the D14 for light pulling of a rolling load. The N series Fords were great little orchard tractors. When pulling against a stationary object my dad showed us long ago to run the chain under the axle, over the transmission and hook back to the chain. This way you are pulling the front of the tractor down. (Be sure not to go over the brake and clutch rods or you get yelled at a lot. So I've heard!!!)
joegrgraham ![]() Silver Level ![]() Joined: 12 Nov 2009 Location: Wiltshire, UK Points: 92 |
Maybe it's just me, but Hager's D19 looks lovely to me, every ding and scrape has a story, the tractors whole life is there, why go and bury it under pounds of filler and two-pack paint. I don't mean to put anyone down, Eddie's done a stunning job on his tractor, I just prefer the 'lived in' look. If it ain't shiny, you ain't afraid to use it for what it was intended.
If it seems like a good idea, do it. It's easier to apologise than to get permission.
redline ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Collins, IA Points: 1013 |
No Lie, Redline...it's the same tractor. Once we got that nasty cab off it and removed the loader, the sheet metal wasn't that bad, and luckily, the previous owner had kept the fenders and grille. Thanks for the compliment.
Here's how the little 8N posted above, turned out...
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2248 |
Dad's '52 WD (with WD45 decals). It's pulled our little pickup truck out a few times, moved plenty of dirt with the bucket, and bush hogged 7 acres every year. It leaks fluid from everywhere and the back rims are about to rust to pieces, but it still does the job and someday I want to give it a good restoration and hook the #53 plow to it.
![]() I can't exactly say that my B is pretty either. Hope to get it going this summer. ![]() |
beeman ![]() Orange Level ![]() ![]() Joined: 02 Jan 2011 Location: Alabama Points: 230 |
That B has alot of potential!! Why the rare , {probably dealer special option}calico muffler system looks to be in excellent condition. {Sometimes my own B gets the grey striped version ...}
1949 B 3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
David Gibson (OH) ![]() Orange Level ![]() ![]() Joined: 30 Oct 2010 Location: Hollansburg, OH Points: 493 |
DREAM ![]() Orange Level ![]() ![]() Joined: 06 Jan 2010 Location: Elberton,GA Points: 1828 |
Eddie, I diddn't notice how much they raised the hood/grille until I saw the "after" pic. You did an excellent job. Lot of daylight between that hood and the head on that flat-6.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3930 |
This old girl can still do an honest days work and will never get in front of a paint gun as long as I own it!!
Phil, that's about as original as they get. She's beautiful just the way she is.
Jeff-in-Kunkletown ![]() Silver Level ![]() ![]() Joined: 13 Sep 2009 Location: Pennsylvania Points: 494 |
Yes sir Phil, that old girl deserves to be left alone. That 45 diesel with the cab looks almost like it factory. Wouldn't want one on mine, but whoever put it on did a nice job.
Sucess is how high you bounce after hitting bottom. Gen. George S. Patton
Dave(inMA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
I helped farm with an 8N when I was growing up here in Massachusetts. Neighbor had a couple of them. We made a lot of hay with them and grew corn for the cows. Made enough hay and silage to feed 50 dairy cows over the winter. All that work got done with those two little machines. I guess "real work" depends on where you are - here on the hill farms of New England would differ from out in the mid-west, I suppose!
WC, CA, D14, WD45
Good choice Phil. I like the originals too. Everything I own has had some new, usually sloppy paint added to it at one time or another. I painted parts of the 45 when I had them off for repair more or less to keep the rust down.
yeah...what split51 says....been on soooo many rescue calls that that happened to the persons running them, not counting the ones i heard of around.
JPG AUSTRALIA ![]() Orange Level ![]() Joined: 13 Sep 2009 Points: 767 |
hey WJohn that is acool looking cat on the b there,looks like its dancing on the hood!
Sorry about the cat, guys... I took those pictures maybe half an hour after the tractor was delivered, and the cat was already climbing around on it. I think she's stretching in that picture. She's pretty good company when I'm working on the B.
JohnCO ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
A school classmate lost her mother when she hooked a chain on the upper link of a borrowed NAA Ford and had her other daughter pull her backword with a IH M. She didn't survive, the daughter has had a hard life since, divorced twice. Got to blame some of the problems on what she helped happen to her mom. In fact my classmate also divorced because of emotional problems.
Allis Express participant |
jb from md ![]() Silver Level ![]() ![]() Joined: 06 Apr 2010 Location: Keymar MD Points: 450 |
This is my 55 wd45 i cant be without it long enough to paint it
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
tomdavison ![]() Bronze Level ![]() ![]() Joined: 03 May 2010 Location: Canton, PA Points: 49 |
I agree with Dave(in Mass) We had a large number of farmers in NE Pa that had 8N and or 9N Fords. In most of these farms (dairy) this was the only tractor they had. These may hafe been too small for larger midwest acres, but were good little tractors in this area By the way, pulling trees or logs is dangerous with any tractor. We had a couple killed pulling logs with a M.
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
All my WD45's can't find a paint gun to make them look new and some of them last looked at one back in 1957. Boys that not rust on them, it's called pitiana! lol
Here's the one with the most pitiana on it. But she lives to cultivate corn. lmao
Don
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8722 |
Eddie, that D 19 is awesome!! The D 19 is one of my favorite Allis tractors, and that restoration job makes me like em more. darrel
Hey guys, thanks for all the responses and the compliments. As much as I like restoring tractors, some are just meant to be left in their work clothes, ( Alberta Phil's is the prime example). Heck, even I prefer to be in my work clothes!
Seems I struck a cord with that photo of the 8N, and although 75% of our restorations are AC's, we've had a large demand for the little Fords. Even one, I'm proud to say that we did for the TV actor, Kirk Cameron in L.A., that he used in one of his movies. Most are wanted for show and work duties, folks that have 10-20 acres to maintain, but still want something to take the kids to shows with.
We have another 6cyl. Funk 8N in our shop now, and we're planning on refitting my dad's V8, 9N over to an 8N chassis this summer. Talk about safety issues, ( my father on a 130 hp 8N, with overdrive...I'd better start working on a Nascar style cage to put on it. Actually, any of the Funk conversions are fun, if you should ever get the chance to drive one. Here's a couple of pics of dad's Mercury V8,...have any of you ever seen a rear-mount Dearborn loader like this one. I included the pic of us with Kirk, outside his home in L.A. Thanks again, and post more pics, Eddie..
Page 12> |
