Spark plugs
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: Spark plugs
    Posted: 25 Aug 2026 at 2:51pm
I have a bunch of new shorter cj8 champion plugs my uncle gave me that he ran in his weed eater. Can I use them for my allis b?
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2026 at 3:22pm
not really a good plan.. the REACH is to short into the cylinder.. you will be burning on the last couple thread in the head.. many people are using NGK plugs instead of the older Champion in the B- C engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2026 at 3:39pm
Ok thanks just thought why buy new if those would work. I will never use them for anything else.
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2026 at 1:51pm
None of the local parts stores have autolite 395. Only thing I could get was Champions J8. Wow what a difference. It’s running better than it has for a long time.
It did have one fouled plug, wet, shinny black. The other 3 was dry black. So must be running rich. The high speed adjustment doesn’t do much , so something must be plugged. I will order a carb kit.
Edited by john2189 - 27 Aug 2026 at 1:55pm
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 2:53pm
https://www.sparkplug-crossreference.com/convert/AUTOLITE/395
WOH - the J8 is a short reach plug - 3/8" and the 395 is a long reach - so it works but if and hen you go to replace plugs later the threads in hole will be fouled from using wrong plugs -
 J8 might work but will cause trouble later - Try Champion N5
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2026 at 4:17pm
Well the head is probably already screwed up. It had 3 Autolite 295 and one Champion J8 from the previous owner.
I must have misread Steves earlier post, I read it as the cj8 was a shorter plug, not the reach.
So I guess running the J8 won’t do much more damage.
If i ever take the head off, I suppose I could get a 14 MM thread tap and clean up the threads.
Probably would not be a good idea to do it without taking it off.
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2026 at 12:12pm
Will the threads be burned up/melted or just carbon fouled?
'41 Allis B
'49 Farmall Cub
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2026 at 1:10pm
If a short plug is put in a long head carbon will build in the exposed thread. In order to put the proper long plug in you will have to run a tap in it to clean out the threads. I went thru that in a D17
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2026 at 1:16pm
The danger is if a person isnt paying attention and they try to screw a long plug in where a shirt plug has been its possibke to ruin the threads
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2026 at 5:08pm
Be best to run a 14mm tap through threads and install correct plugs. Spin motor over with plugs out to take care of carbon dust. Lightly oil threads on plugs. Done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2026 at 5:31pm
Thanks
'41 Allis B
'49 Farmall Cub
