D- 17 belt pulley question
Al53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al53 Quote  Post ReplyReply Direct Link To This Post Topic: D- 17 belt pulley question
    Posted: 01 Feb 2023 at 12:40pm
Will a hydraulic pump off a series IV D-17, bolt on to the belt pulley location of a series I D-17? Is there some gearing that will make it not work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 12:51pm
No , I am sure it can be done but be better off with a front mounted pump. Would probably have to swap parts from an existing tractor to make it happen
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2023 at 2:43pm
I researched that possibility many years ago.  Of course the pump will bolt up to the housing, but will it work like you want?  NO.  The series 4 torque tube had to be redesigned inside for the side mount pump to work as intended.
