D15/I600 questions & parts wanted
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: D15/I600 questions & parts wanted
    Posted: 15 Feb 2022 at 5:56am
I just bought a I600 backhoe.
Looking for a tuneup kit. Points plugs n such?
What weight oil is recommended?
I’m led to believe it uses tha same oil filter as my old Ford truck? Ph8a.
Where could I find manuals for this? Tractor, hoe and loader?
Is it worth a electronic ignition upgrade?
Not a show piece but a worker.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 4:20pm
   I600 has a 160 cu.in. engine same as a D-15 Series II.
You can get ignition parts from NAPA.
G
https://www.tractordata.com/industrial-tractors/000/0/8/85-allis-chalmers-i600-engine.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2022 at 8:45pm
I asked the young guy at Napa today and all I got was a funny look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 5:01am
Also hunting an air filter or an air filter number.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 5:25am
Thad, Wix site says 42276 for the air (2276 at NAPA)
FYI, I have a PDF of the I600 parts book you’re welcome to, I’ll shoot a download link to your email in a bit
Joe
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 5:48am
Thank you Joe.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 5:51am
Delco distributor with the cap held on by two screws?   If so the following Standard Motor Products part numbers should work.  NAPA can cross these to Echlin, they are common items.
Cap   DR437
Rotor    DR 314
Condenser   DR 60
Contact Points  DR2240
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 6:12am
Cap   DR437
Rotor    DR 314
Condenser   DR 60
Delhi distributor cap held on with 2 spring clips.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 6:23am
Delco with two clips I could help you with Delhi I have no idea.  Any identifying numbers on it?  Can you post a picture of it with the cap off to show the points and condenser, that might help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 6:52am
Delco, apparently spell check doesn’t like them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 7:09am
Here are the SMP numbers for the common Delco two clip cap distributor:
Cap   DR 405
Rotor    DR 321
Condenser   DR 60
Contact Points  DR 2227P
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 7:38am
<div style="color: rgb0, 0, 36; : rgb254, 252, 212;">Cap   DR 405
<div style="color: rgb0, 0, 36; : rgb254, 252, 212;">Rotor    DR 321<div style="color: rgb0, 0, 36; : rgb254, 252, 212;">Condenser   DR 60<div style="color: rgb0, 0, 36; : rgb254, 252, 212;">Contact Points  DR 2227P
Thank you very much sir.
I truly appreciate you.
