185 upgrade valve cover bolts
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Topic: 185 upgrade valve cover bolts
    Posted: 08 Mar 2021 at 7:24am
Hello Guys,
I've been busy and haven't been on for a long time, but everything is good.
I'm finally giving my 185 Diesel some overdue TLC. The pump is off and sitting at Ed's shop for a rebuild.
The valve cover has been leaking pretty badly so I'm fixing that too. A few years ago, someone was talking about upgrading the 180-185-190 valve cover bolts to a style off the newer tractors that had an internal spring to hold the right tension. I forgot now but I'm guessing it was of A 7000.
I looked up the 7000 parts book and I think bolt 74036972and washer/spring 74036973 is what I need.
Can anyone confirm this is correct and is this actually worth switching too?
I'm sure there's a different torque spec or something I should be using when installing the new style.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 7:41am
Get a 74036977 kit and follow the instructions that are included.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 7:51am
Yes, the bolts and spring washers will work, but regular bolts will also if proper glue and properly torqued .       1/4x3/4.            MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 8:23am
Thanks guys. Kit ordered form Sandy Lake $60
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 8:24am
Kit from Agco is 52.38
