Hydroulic Fitting Size
bendts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bendts Quote  Post ReplyReply Direct Link To This Post Topic: Hydroulic Fitting Size
    Posted: 02 Nov 2020 at 3:58pm
I may just be confusing myself here.  I got the 3/8 NPT & 1/2 NPT size... But what is the fitting size on the steel tube pressure/sump Flare fittings?
Are they NPSM / NPTF connections?
1960 D17 Gas # 28849
Kevingweq View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevingweq Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2020 at 5:47pm
That style fitting is called an inverted flare (think brake lines ) Be cautious on mixing and matching as there is some variations on flare angles (degrees)
https://www.jiayuanfitting.com/info/sae-thread-inverted-flare-fitting-size-chart-44478469.html
Edited by Kevingweq - 02 Nov 2020 at 6:08pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2020 at 6:05pm
it is called a 3/8 or 1/2 inch TUBE FITTING.... inverted flare
Post Options Post Options   Thanks (0) Thanks(0)   Quote bendts Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2020 at 6:21pm
That is one of the charts I was looking at.
Are there any adaptors that will allow the connection of a standard Hyd Hose with either NPT or JIC fittings?
I need to run a pressure hose back to a 3 spool control, and need to connect to the brass female that comes out of the pump.
Arcs and Sparks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcs and Sparks Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2020 at 6:47pm
As far as adapters go the options are endless.  For a few of the options just search Northern Tool for hydraulic street elbows.   You can adapt 3/8 NPT to tube, NPT back to NPT, NPT cross over to JIC etc.  Most are available in male to male, male to female etc.  If you want to go with a tube fitting that is almost impossible to have a leak from, you can go to industrial tube fittings.  These are crush type double flare fittings rated up to incredible pressures.  They are pricy but very simple to use.  In that case search the options at Swagelok.  These are just a few of the possibilities.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2020 at 6:55pm
A shop that makes hoses, can make a hose with that type fitting on one or both ends, which ever you need. I've had hoses made with 90° inverted flare fittings to replace some tubes, like that one.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2020 at 8:58pm
Thank the world for the JIC fittings.        MACK
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2020 at 10:30pm
Measure the OD of the tube. That will tell you the size of the inverted flare fitting. If it is 1/2 in. it will have a 3/4-18 thread on the nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bendts Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2020 at 6:18am
OK, I see those fittings on deeper searches now.  I figured there had to be something that would match up.
Thanks
