Engine Weights Allis Chalmers B
rhaley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhaley Quote  Post ReplyReply Direct Link To This Post Topic: Engine Weights Allis Chalmers B
    Posted: 01 Sep 2020 at 3:02pm
There are engine weights on my 1940 Allis Chalmers B.  The first picture show the peg at the front end sticks into a hole in the front of the weight.  Does anyone know if these pegs were put on at the factory as an option or installed when the weights were purchased.  I have a 1939 B that I got a set of weights for, but there is not a peg on the front of the tractor.  Looks like it would be easy rig up, but I would like to know if anyone know what was originally done.
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 4:01pm
That style of weight wasn't available initially, so a 39 would not have the holes in the front plate from the factory.  Later models have a hole on each side, where a bolt and bushing went through, creating the "peg".  You could certainly modify what you have to mount a set of the weights, if desired.
Post Options Post Options   Thanks (1) Thanks(1)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 4:58pm
Here's a picture:
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 5:58am
hmmm...any chance you could weld/fab a 'peg' that slips over/hangs onto the cast part  instead of drilling the hole ? That way the 'correct cops' won't be on your case !
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhaley Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 8:04am
yes - it looks like there is room for that.
