8.3 cummins into 7060
Dafydd7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dafydd7060 Quote  Post ReplyReply Direct Link To This Post Topic: 8.3 cummins into 7060
    Posted: 11 May 2020 at 8:56am
Hello All
I'm new to here all looking for some help from all the experts
Im based in the UK and have a 7060 and a 8550
Unfortunately, engine in 7060 has gone and have an 8.3 cummins engine to put in it.  Bought an adaptor kit from Leamans tractors
The oil pan on this engine has a front mounted suction pipe.  I've had to reverse the oil pan for it to fit because it hits the front axle.
When it is reversed the other end of the oil pan is very shallow and the oil suction pipe prevents the oil pan from closing.
Has anyone done this conversion and managed to sort this problem.
Also, how do I get round the front mountings problem?
Hope someone will be able to help.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 9:52am
Have not been around the Cummins to know how they are made but often when installing combine engines, they trim front plate ears and use angle iron bolted to inside frame rail then weld the 2 together
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 8:10pm
Welcome to the AC forum.
I would recommend contacting your engine adaptor plate source & ask them. Those businesses usually know about numerous issues associated with engine swaps.
From which application did your doner Cummins 8.3 arrive? Ag Tractor? AgCombine? Construction Equipment? Truck? GenSet? Etc?
For your AC7060 (AgTractor) application, you might look into the CaseIH magnum series oil pan at a salvage yard?
Edited by AC7060IL - 12 May 2020 at 5:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 9:30pm
Heres a truck 8.3 oil pan weblink that shows different Cummins part numbers & photos. 3924017 & 3924010 have about 3/4 moderate depth drain and 1/4 smaller squared-off deep sump. 3914013 is divided half deep sump & half shallow drain.
https://truckpartsinventory.com/oil-pans-cummins-6ct-8-3-parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 9:37pm
In this link, scroll down to pages 78 to view 8.3 oil pan Cummins 3914015. It has a larger center sump with short drains on each end. It has shows oil pump suck tube. I believe this one is used by most of the case-IH tractor & combine applications.
https://mart.cummins.com/imagelibrary/data/assetfiles/0057274.pdf
Edited by AC7060IL - 11 May 2020 at 9:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 9:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dafydd7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 3:23am
Hi
Thanks for your reply
The engine came out of a Dennis Fire Truck
The part no of the sump on it now is 3910874
Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dafydd7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 4:37am
Thanks for the info
Will look into it
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 5:26am
Originally posted by Dafydd7060 Dafydd7060 wrote:
Hi
The part no of the sump on it now is 3910874.
Thanks again
It’s always nice to know part numbers - thanks for sharing yours. So this link’s Cummins oil pan looks like yours? (Same as 3914013)
https://m.aliexpress.com/item/32455891538.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 5:44am
Instead of swapping oil pans, you may just need to swap oil pan sump tubes??
When searching for this engine’s parts, try both Cummins “6c8.3” and/or “ISC”.
Here’s a Cummins oil pan sump tube link. It contains lots of engine models; ISX, N14, ISM, L10, ISC, 8.3, ISB, 5.9, so please scroll thru them til you find ISC or 8.3.
Or you could pick 8.3, ISC, 504, etc from their model search at top of page. Hope it’s helps
https://www.vanderhaags.com/Search-Results.php?manufacturer=cummins&inventorytype=engine-oil-pickup-tube
Edited by AC7060IL - 12 May 2020 at 5:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dafydd7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 11:32am
Yes that sump is the same
This page was generated in 0.906 seconds.
