Starting Allis Chalmers by crank?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: Starting Allis Chalmers by crank?
    Posted: 10 May 2020 at 8:46am
Anyone have a good video on the proper method to start one by hand? all I remember is growing up that my dad always had problems starting with his battery/now mine Allis Chalmers b (so he would always be crank starting it)
Two things I remember were him always telling me do not get your head in the way of this if you ever start it this way (also heard rumors of it breaking people's arms if not done correctly)
And number two on this particular tractor the carb always flooded before he could get it to start the very first time so he would have to drain the carb and then it would pop right over
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 10:46am
Cranking, keep all body parts out of the swing.  DO NOT grasp the crank with thumb under handle, no baseball bat grips.  I always place my thumb on top with my fingers.  I run crank around to about 10 o'clock, stand on the left side of tractor, place right hand on top of the radiator and pull towards me while pushing myself away from tractor with right arm.  Left hand pulls crank around.
I learned the hard way, not once but twice, NEVER grab the crank with thumb on bottom.  A backfire both times... death grip on crank, both times it was a couple hours before I got my arm/shoulder feeling back and hurt for a few days (WD).  I'm told poor timing causes the back-fire, I'm not an expert and won't argue that point, probably right.
On my WC, full choke, usually one pull and the gas drips out.  Choke then to half and it fires on 2nd pull, 3 at most.  Throttle on idle.
I cringe every time I see those he-men stand in front of a tractor and grab with both hands and spin.  All it takes is one oh-poop to spend many hours in the emergency room.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 11:02am
Hmmmm, sounds familiar to my dad's words but a bit hard to visualize I guess
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 11:41am
https://youtu.be/N43_dWx8Yrs
https://youtu.be/uOMBzGhteHU
Edited by HoughMade - 10 May 2020 at 11:41am
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 11:42am
you cup hand on crank not having thumb around crank no matter which way you are pulling handle...when things are right you should be able to pull crank gently (not fast,not slow) and when the impulse on mag snaps it takes off running.....distributor is little more tricky...it should still fire after TDC if advance and timing are right....hand cranking can be dangerous  so be CAREFULL!
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 12:20pm
What NDB said is exactly how I was taught.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 6:55pm
Does it have a distributor? If so does it have an anti kick back rotor in it? Best thing that was ever invented for hand cranking.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2020 at 10:57pm
Hand-starting is a good thing to know how to do...
but...
"my dad always had problems starting with his battery/now mine Allis Chalmers b (so he would always be crank starting it)"
Uh... this usually means there's a bad ground or battery cable... and what's happening is that the battery has plenty of power, but resistance in the engaged starter motor is extremely low, but the cables and connections are resistive, which causes the voltage from ground to B+ has dropped to close-to-nothing.
I suggest you remove and replace each of the battery cables, clean the posts, and the contact point for the ground cable, dismantle and clean up the starter motor switch contact, replace the coil primary wire (from ignition switch to the coil), replace the ignition switch, and wire from battery to ignition switch, and also remove the coil, scrub the mounting boss shiny, scrub the coil mount bracket, and clean and scrub the coil where the bracket grips it... and try the electric starter...
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 8:22pm
The old WC with crank that stays put and nice guides and release spring makes you feel a lot more secure about using it.   My B has a crank but I never thought it worked nearly was well, even though it is a magneto tractor.
When I was growing up, I never saw a tractor get cranked by hand. I think I asked about it once since the WD had one stored on the fender... and my uncles just laughed at me. I don't think the distributor tractors and higher compression engines were near so friendly.
My 1941 Mercury with Flathead V8 still has a hole in the radiator and front grillwork for a crank. Never seen anyone try it on cars of that era either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2020 at 8:49pm
Ok thanks
I only would use it in a pinch ( not regular basis)
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 1:00pm
Big log chain and yank that sucker down the road til it starts!
Cranking will kill you IF you even are remotely afraid of doing it! ---It's one of them things that you either just go do OR if afraid of it----then be safe and dont do it.
There is no right or wrong way--its whatever works for you. I gotta have my thumb around the crank!
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2020 at 1:33pm
Back when I was about 12 years old we used an unstilted WC for the summer. I drove it hauling hay wagons. I had to wait for each wagon, and my dad would not let me crank it. So I had to let it sit and idle, or someone would have to come and crank it.
O could park on a hill, but it had to be chocked when cranking and the chock rod only went to the front. So I got a piece of fence wire from a junk fence, and ran it from the carb to within the seat. Then I could start it by parking at the top of a hill, and coasting down it.
In about the summer of 1964 my '53 WD with 6 volt batter ignition had a weak batter. I had to crank it every morning, then the starter would start it the rest of the day.
It rained for 2 or 3 days, and the battery would not even provide a spark.
So I hooked a 6 volt lantern battery to the ignition and hand cranked it. It started right up.
This was before we had jumper cables.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 6:50pm
Many winters ago we had a real cold day in January and none of my battery tractors would start. The old WC started with crank no problem. I used it to move firewood that morning while the other tractors were on charge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2020 at 7:03pm
There is a 'right' and a 'wrong' way... although, when the engine is properly timed, and has a magneto with an impulser, it is much, much, much less likely you'll ever experience a kick-back, as when set up properly, it doesn't fire until AFTER top dead center, the engine will always make it's firing events in the forward direction.
My '28 Model A Ford, like all others, has a mechanical distributor manual spark advance.  Set it wrong, and it will break your arm EVERY TIME.  My '24 Model T Ford has flywheel magneto-generator with buzzer-coils.  To generate enough energy to get ignition, the engine needs to be cranked briskly... and if not set right, it WILL break your arm.
My Fairbanks-Morse ZC-118 and ZC-208  both have magnetos with impulsers.  Turn on fuel, roll them over twice, lift the magneto ground switch, pull the flywheel past TDC, and it will fire in the proper direction.
I have a 35kw generator with Hercules JXLD 338ci inline six running on propane, with an impusler-equiped magneto.  It has electric starter, but if circumstance arises that it's starting battery is inoperative, I can engage the hand crank, turn on gas, hit the regulator's prime button, step on it once, lift the crank one notch, step again, lift the crank, lift magneto ground, step on it the third time, and it's alive.
I see WAY too many modern machines that require grinding-away of a starter motor to fire up.  ANY internal combustion engine, when properly set right, should require no more than two full turns of the flywheel in order to start.  If they do, there's something wrong.  Fuel + Oxygen + compression + ignition = fire.  With proper timing, it will go in a forward direction, and every other cylinder should follow.   Any OTHER circumstance means fuel, oxygen, compression, ignition, or timing are insufficient.
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2020 at 7:06pm
Grew up with a '49 WD narrow front, we never had a battery in it until long after I graduated from college. Dad never had the money for a battery, and the generator didn't work anyway. Always crank started it-still do on occasion. NBD has the right instructions. I never considered it a dangerous thing to do, just part of using the tractor.
