Electric Wheel Co. running gear |
Dean(IA) ![]() Silver Level ![]() Joined: 12 Sep 2009 Location: NE Iowa Points: 430 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Apr 2020 at 1:10pm |
My neighbor has an Electric Wheel Co. running gear according to the data plate. It is orange and sure looks like the same running gear that A-C sold. I know that Electric Wheel made many of the rims used by Allis. I can post a picture if that would help. Thanks, Dean PS, We are safe and warm and fed, so we feel Blessed. All of you, stay well and God Bless you all.
Dean(IA)
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3530 |
Yes electric wheel manufactured multiple brands of wagon running gears throughout their years. Among the brands that they manufactured for are as follows; Allis Chalmers, Case, David Bradley(Sears),Dakon,IH, MF, New Idea, New Holland, Minneapolis Moline, Oliver, & Wards((Montgomery Wards).
Edited by AC7060IL - 03 Apr 2020 at 4:07pm |
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
Must be they made them to the specs called for by each company. We had a couple of New Holland, and they sure appeared to be better than some of the others. Sears for one.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5009 |
I may be completely wrong, but I thought Badger wagons were made by Electric.
Here’s a great article link that discusses EWC’s beginnings. I believe Art’s Way may have also had EWC mfg their earlier running gears?
https://www.hsqac.org/company-once-had-largest-wheel-shop-in-world Here’s another link that shows a cool older black/white photo of EWC dock workers loading rail cars & delivery trucks with wheels http://www.idaillinois.org/cdm/ref/collection/qpl/id/1449 Edited by AC7060IL - 04 Apr 2020 at 10:32am |
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1029 |
It really doesn't matter. Any running gear including Electric and AC with no way to grease the steering tie rods are JUNK. After just a few years of normal use they are done. I have owned them both and I'm talking from experience. After a short time of use try towing them down a highway and see how fast you get before they are all over the road.
Ky.Allis, I disagree. Junk is such an absolute term. EWC’s wagon gears were built well during their 1960-1970s era. You’re correct about their non-grease zerk tie rod ends which contain either a plastic or metal wear bushing which can be disassembled, lightly greased, & reassembled using an impact wrench in about 2-3 minutes per side. Please note: The tie rod end attaching bolt threads into it’s tie-rod cast housing on 10-12 ton gears(And maybe on the 7-8 ton gears?). If maintenanced once per season, they’ll last.
I too own & operate 5 different EWC built branded gravity wagons for decades. My experience has been that the critical steering slop that you suggest results mostly where the tongue’s rear attaching pin wears itself & wears both ends where it connects to the steering center pivot. All of mine will behave while being pulled empty behind pickup at 50mph. The worst brand seems to be the EWCs inthat their tongue/pivot assemblies resembles the older narrow David Bradley style. The New Holland & Wards assemblies are similar. They require a more snug pin to reduce slop. The AC, NI, MF, Dakon, Case, & IH generally have a wider flared rear tongue that allows more stability where it connects to its pivot. Edited by AC7060IL - 05 Apr 2020 at 4:29pm |
Your right!! If you took the time to disassemble the steering rod joints and lube them they would last longer. But greaseable ball joints have been around a very,very long time and how much more would it cost to add them to a wagon running gear to drastically increase it's life and make it so simple to hit with a grease gun a few times per year.
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1488 |
I have drilled and tapped tie rods and ball joints on automotive stuff and installed grease zerks. Maybe some of these could be as well???? Has anyone tried? I’m not familiar with these running gears so totally guessing.
