snow stops for steel roof?
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: snow stops for steel roof?
    Posted: 21 Mar 2020 at 5:17pm
I have a steel roof I need to put snow stops on. Looking for suggestions. Opinions on glue on vs screw on. This is 12-12 pitch roof with what I call barn roof steel. Has any one made their own? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2020 at 8:53pm
guess if I had to put them on, i'd use anything that didn't put any holes in the tin. I would rather have the snow slide off than stay there adding weight to the roof. if it's over a doorway, then maybe add a gutter or a small extra roof for it to slide away from the door farther. I do know some towns require those stops on the roofs, I just don't care fore them...it's just my thoughts right or wrong.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2020 at 9:00pm
 UMMmmmm,,,what are snow stops,,???
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2020 at 9:04pm
they is little thingy's you put on the roof to keep the snow from sliding off in a big swoosh all at once, catches it and so it melts off or slides a little ata time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2020 at 9:51pm
well I've got them( think of 1" square bars)  and they don't work......they actually trap and backup the snow,then when it gets warm enough... freight train time.....2-3-4 minutes of a HUGE avalanche.....OK, it's dozens and dozens of smaller chunks coming off, but it ends up being a huge friggin mini mountain range... I don't bother about the back deck, but I do immediately remove the mess by the front basment  door. otherwise it'll become an ICE mountain and impossible to move.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 6:49am
The reason I am considering them is that when the snow slides it damages my gutter system. And it's on the north side so the snow builds up. Snow coming off a pitch like have takes no prisoners.
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 8:27am
They get put on all the standing seam roofs we build for the company I work for they are called snow guards.
Trying to remember, believe we used the glue type only once.
They do work to kept the gutters and snow from coming off in sheets.
Typical ones I see is they clamps on the seam with a rail then pieces come down in the middle of panel.
Edited by Richardmo - 22 Mar 2020 at 8:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 8:38am
Are specialized to style of roofing tin. Ours are a simply 'V' form screwed on at intervals thru the Standing rib with Specialized longer screws.
Not so much Snow Stops but called "Ice Dams", This is best photo I have of them, put them anywhere have gutters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 8:39am
 Well,,,that just goes to show how much I know bout "Snow Country" stuff,,,,,,Wink
 But,,I still cannot see the reasoning behind trapping the snow ON the roof and adding a ton of weight on said roof,,,,?
 IF there is a city mandate that all roofs have these snow "Traps",,,, then the mayor of said town prolly has a Bro-in-law that owns the company installing those dang things,,,,,LOL
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 8:54am
The reason is to stop the snow from coming off in one big sheet. The snow doesn't just melt like on an asphalt roof it slides in big sheets off the steel roof. This is at my cabin and I don't heat it in the winter so the snow builds up anyway. In my situation I don't worry about the weight.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 11:10am
You have a 12 12 pitch no snow will stay on that pitch no matter what snow guard you use. The newer hangers we have the glued on plastic ones they at least don't ruin the roof when they get broken off. The older hangers have screwed on steel when they come off they sometimes take part of the roof steel with. The very steep pitched hanger fronts have steel stand offs welded to plates and cross rides between the stand offs they are a 12 12 pitched roof when enough snow builds up it creates a ice dam glacier that when it finally breaks free it come off with enough force to kill a person we had to retro fitt steel awnings over all the hanger entries they are made of 1/8" steel twice the width of the doors and look like they been hammer with a sledge.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 12:10pm
Dave sounds like you have dealt with this. Any suggestions on how to save my gutters?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 12:44pm
Our Ice Dams do not attach to the Tin only, they are screwed to the Underlayment I specified UNDER the tin. All the roofs except my barn have 3/4" T&G Underlayment, on the Barn they marked the Trusses/rafters and set them to those when installed. Screws were 1 1/2" long.
This page was generated in 0.149 seconds.
