AC Mower 80S or 82S?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: AC Mower 80S or 82S?
    Posted: 11 Feb 2020 at 6:43am
Just purchased a side mount mower for my WD. How do I tell if it’s a 80S or a 82S? This is a trip mower. PTO shaft attaches to a rear mounted assembly driven by a drive belt off a pto pulley. That pulley also has a male shaft that can power a pull behind hay conditioner. Need to order a manual for it.
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 6:54am
80S has frame that goes back to drawbar mounts. 82S mounts just to siderail and only PTO shaft goes back. If it's a 80s I may have a manual and some extra parts you can have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:34am
It has the mounting plate that bolts to the frame only on the right side. So I guess it’s a 82S. PTO shaft is the only part going towards the rear of the tractor. The drive assembly slides over the pto shaft on the rear of the tractor and bolts to the hitch.
Thanks Gary
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:38am
Side mounted frame is 82S.  Huge box frame is 80S.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 9:02am
Isn't the 80 cable lift and 82 hyd lift.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 9:07am
Yes, 80 has a cable that runs back to the lift arm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 9:07am
Yes.  The 82 has the small side mounted frame.  The 80 has the massive rectangle frame that mounts front and rear.  The 82S really is a side mounted mower.  The 80S is more of a mid mount.  80S is really hard to mount and the 82S is hard on radiators.
AaronSEIA
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 10:21am
AaronSEIA
You didn't explain.....I'm assuming because it might have a tendency to twist the frame?
I have an 82S on a WD-45 and haven't had that problem. However, I did attach a link to the LH frame to provide more lateral support.
The 82S is far and away the better mower not only for ease of installation but because improvements were made in the hinge system using ball bearings, increased thickness of the bar from 5/8" to 3/4" and a much heavier "cage" around the gear box.
Some of the later 80S mowers may have also benefited from those improvements but I'm not sure.
The 82S has its own hydraulic cylinder which gives it the ability to be raised fully vertically right from the seat.
Edited by Brian G. NY - 11 Feb 2020 at 10:25am
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 10:56am
I've never seen a 82S that would raise completely vertical,only the 82SI would do that I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 11:21am
Believe me, they can be "tweaked" to do it.
I don't know whether or not they are supposed to do it....I messed with the chain lengths
a bit to make it happen. Where I mow, it makes life a lot easier and you can 'trim" the small limbs on trees while you're mowing.
I don't even have a support rod on mine.
I cut my bar down to 5-1/2' to get around the scrub apple trees easier which probably makes it pop up a bit easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 11:53am
Originally posted by Brian G.  NY Brian G. NY wrote:
[QUOTE=AaronSEIA]
AaronSEIA
Dad shook the radiator out of his WD twice running one.  Just too much vibration hanging off the frame.  I'm sure I'll be told his is the only machine that ever happened to.  In my experience none of the 80/82 mowers as balanced as they needed to be to run smooth.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 12:05pm
[/QUOTE]
AaronSEIA
[/QUOTE]
They run fairly smoothly when everything is set up correctly......I thought cutting a foot and a half off the cut bar might cause some balance problems but its not noticeable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 12:28pm
I've run 82S mowers on a D19 and a D14 never seen where it had more vibration than any other sickle mower.What will cause excessive vibration is running a dull sickle,which I always ran a sharp one,new sickle assembly at least every year and never tried to run one that was so  called 'sharpened'.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 12:49pm
What?
Dad would grind the sickles and reuse them as long as he could. Tongue
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 4:33pm
Neighbor farmer used to loan me a mower tractor every year to clean up around the property before I had a tractor of my own. The first one was an 8N with a side mounted Dearborn sickle mower that also raised vertical with hydraulics. Then, he got this nice D-17 with an 82S mower which he also loaned me.
The one thing that always amazed me was how he cut straight corners without stopping.
I had always thought that was possible only with a rear mounted mower.
When he came to a corner, he would pull the PD into low, hit the right brake and give the wheel a quick turn and the bar would come around and make a perfect corner without leaving a stalk of hay. Power steering was a big help in making this possible. This picture of me on the borrowed tractor was taken in 1965.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2020 at 7:50pm
Charlie is correct, dad sharpened the whole bar on a narrow bench grinder. No teeth left and it still mowed well. I’m replacing all the knives and attaching with bolts instead of rivets. So much easier and quicker to service the bar. The mower has the hydraulic lift. From a picture I found on the ole web, the mower mounts farther forward than I would have thought, Charlie said probably due to the trip ability which makes sense. Looking forward to getting the manual and installing it to see how it does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 5:41am
Most people I know that sharpened sickle bar mower sections quit using a sickle bar mower and went to a haybind because the mower wasn't getting the job done.I still cut all my hay with a sickle bar mower and get it  cut just fine.
No amount of sharpening will get the section back to cutting like it was when it was new.I have bought a lot of sickle bar mowers over the years that I assume were being used to cut hay of some sort and I have never bought even one with a blade in it that I would take to the field to cut hay.Even a slightly dull sickle will cause all sorts of problems.And I'll take rivets over bolts too but that is another discussion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 5:58am
Granted, ours was mainly used for pasture mowing and other stuff later in life after dad got the 390.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 6:00am
Not to hijack the thread, but dad's mower is a 80R3 that he bought new in 1968 along with the D15.
Looks like the R3 came out in 1963 but it looks like it was still made for a good while overlapping the 82 series?
Charlie
Farmerjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmerjim Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 8:22am
I have a 82s but no mount for my D17, if anyone has one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 10:03am
Gary, I am using bolts instead of rivets for the pure ease of replacing them in the field. Loose rivets or a broken knife requires the removal of the bar to repair. Can be repaired in the field I guess but not so easy. By using bolts I can remove the guard at the effected area, replace the knife and be on my way in 10 minutes or less. Originality is gone, but the time and aggregation it will save me means more seat time on my WD with a smile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 11:19am
What I do is to buy riveted blades they are cheaper and I think the riveted section don't break out as easy.When a section breaks out I take the guard off with an impact.drive the rivet out the blade and knock bolts into the section .Then put the section in and the nuts will be on the bottom so no tall hold downs are needed.plus if you notice the unthreaded
part of the bolt goes beyond the section and into the blade since the section is thinner giving a more secure fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 11:38am
I'll add the New Holland guards that are on the NH 456 mower I'm now using don't have
quite enough clearance for the nuts on the bottom and have to have about 1/8 inch ground off.But AC guards are made a little different and the nut has good clearance so since I have several hundred AC guards around here I'm putting them on the NH mower as needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 12:52pm
As far as the radiator problem maybe you could make a bracket to attach to the opposite side of the tractor and come under it and strengthen  the existing bracket. I have a Deere No. 10 mower on my 2510 and that is how my brackets are.I also have an 82s for my D15 but it needs some work to use again. Tom
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 3:16pm
We have 82S on a D15 Series II. Does good job cutting ditch banks etc.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2020 at 4:20pm
Picked up some really nice Herschel knives for it today. Much better quality than TSC sells and less expensive which shocked me. Hoping to have it mounted by next weekend. Still need to get 2 new belts. One pto locking pin was broken and SLI shipped it out today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2020 at 6:19pm
Installed the side mount today. Working on installing the rear drive assembly also. At over 600 lbs seams like a lot hanging off the frame. Ordered 2 new drive belts, should arrive next Wednesday. Sickle is almost complete, waiting on 10 more knives to arrive. Anyone have a rear safety shield for sale?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2020 at 6:39am
Put a couple extra weights on the rear left wheel,you'll need them on a hill if you raise the cutter bar.
