Allis B Crank J caps
gman54313 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman54313 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B Crank J caps
    Posted: 02 Feb 2020 at 3:25pm
A few months ago I torn down my 1940 B and have been working step by step putting it back together within spec's. ( a big thanks to ALEX at A&W) Today since it was so nice out today in green bay I decided I would install my newly ground crank with .030 under bearings. and install my new liners and 0-rings. When I removed my main bearing caps s a few months ago I marked each one so when I reinstalled I would know exactly which cap went where and in the same orientation. Today when I started with my first journal bearing with thrust bearing attached the cap went in the exact way it came out. The center cap and the front journal cap had to be flipped end to end so the bolt hole would thread in. My thrust clearance is now .003 which is good my crank bearing clearances are good but does it matter on the orientation on my last two caps?
Edited by gman54313 - 02 Feb 2020 at 3:31pm
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 4:12pm
If by end to end you mean 180 degree's you should be fine. Just can't move from one location to another. Can't put the center one in front and the front in center unless you get the block line board to assure proper the edge of the cap journal matches the edge of the block journal
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman54313 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 4:30pm
You are correct I do mean 180 degree's Thank you.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 7:19am
They have to go back just like they came off.(providing they were on correct) Bearing caps go on with bearing tabs on same side of block.       MACK
This page was generated in 0.172 seconds.
