mice chewing on radiator hoses
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Topic: mice chewing on radiator hoses
    Posted: 02 Oct 2010 at 2:22pm
Does anyone have a  home remedy to stop mice from chewing on radiator hoses? They have started to chew on the edges of the hoses on our L-2 combine. We use moth balls, rat poison, and even bars of Irish Spring soap to keep them out, but they can't resist the smell of antifreeze.
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 2:30pm
put a small bucket about 1/2 full of used antifreeze mix around the engine compartment and leave it for 1-2 weeks.  You will find them floating in the bucket.  Around here I drain all the old antifreeze into a bucket (to keep it off shop floor) and before I have a chance to dispose of it in a couple of days there are always mice floating in it.  Don't put it were pets/children can get into it though.
Adam
joegrgraham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joegrgraham Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 3:16pm
To second what just been said, cats especially go mad for anti freeze, and it don't do 'em any good, so be very careful where you put the bucket of fluid.
I got a mouse chewing the battery terminal cover on my truck, and the little buggers have been at my wifes car, two washer bottles, AND the main wiring loom.
I just put plenty of bait stations and traps around the wheels of the affected vehicles, and around the sheds, keep at it and you'll thin them out eventually.
If it seems like a good idea, do it. It's easier to apologise than to get permission.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 3:40pm
An old tried and true home remedy was barn cats.  Not very friendly, but you didn't have any mice problems neither!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 3:51pm
A pail with a lid smaller than the diameter of the pail, hang that lid with one piece of string , centered over pail, bait center of lid, when critters jump on lid to get to bait, lid tips sending them into bucket. A couple inches of anti-freeze in bucket gives them a soft landing and a chance for exercize and something to drink.
 A couple of ramps up to the pail or container gives them access, can be set under things to keep kids and other larger animals out. Or cut holes into upper part of plastic bucket , use the pail lid to secure it and hang the inner tip lid from secure bucket top. Same contents and same results but keeps cats , dogs, and other larger things out.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 5:25pm
Try the newer antifreezes with bitterant SP? in it.  The stuff is horrid.  I was changing my wifes car's antifreeze and saw the label on it.  Remembering being splashed a time or to and knowing how sweet it was, I touched a bit to my tongue.  Several beers later, some milk and bread my mouth was still foul with the bitter taste.
The make a spray, called bitter biter I think, should be at the pet store, for spraying wounds on pets so they don't chew on them.  Spray the outside of the hoses down with that to prevent them from trying.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 8:38pm
ONE MORE QUESTION.WILL ANTI FREEZE (ETHLYENE GLYCOL) WORK ON CAT SQURILLES??
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 8:49pm
I wonder if that "Bitter Biter" would work in cabs?  Or would it smell too bad?  The mice have just gotten terrible the last few years.  Can't keep them out of stuff.
I used B100 biodiesel for a few years until it got too expensive.  Had a real problem with mice chewing the fuel lines, that and the fuel lines going soft from the biodiesel.
Allis Express participant
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2010 at 10:16pm
Antifreeze will pretty much kill anything that drinks enough of it.
This page was generated in 0.127 seconds.
