Thompson/Thomson D-17
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Topic: Thompson/Thomson D-17
    Posted: 07 Oct 2019 at 2:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 2:26pm
Check out the spelling on the wheel and axle castings......
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 2:28pm
What does one do with this hitch?
It's a 63 model, diesel and it is supposed to run. I understand that these were hard starters. Anyone know of a gear reduction starter that will work.
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 7:26pm
Should not need a gear reduction starter.
Does need a good battery and the manifold heater working.
If no heater just a little bit of ether and they will start as long the pump is good.
The hitch was used for the cane equipment,
They could use the row builder that was used on the WC or WD/UC cane tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 10:05pm
Thanks Rich. I know you know these tractors. I will clean it up a bit, change some fluids, battery cables etc. and see what happens.
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 10:22pm
Did Thomson use other brand of tractors or just Allis?
JeremyShaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeremyShaw Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 2:24am
I'm waiting for more information about engine starting 🚜
Edited by JeremyShaw - 09 Oct 2019 at 4:13am
https://www.agridane.com - Specs of agricultural machinery
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 9:13am
Probably be the weekend before I get to it. Gonna get a good battery, make new cables, pull the starter apart to see how it looks, clean the tank, new filter, change oil, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 9:15am
Harold, Tompson was located in Thibodaux Louisiana, I'm a 30 minute drive from there. I don't have any knowledge of them using any other tractor. At one time AC was king in cane country down here.
Edited by lowell66dart - 14 Oct 2019 at 7:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2019 at 7:42am
Got some things taken off without breaking a bolt!!! Gave it a good bath too. I need to rebuild the battery box and rewire it next. Posted an ad in the classifieds for things I need so far if anyone's parting a D-17.
200Tom1 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2019 at 5:16pm
Did those come with 2 -6 volt battery's hooked up tout out 12 volts?   My series 4 diesel has 2 -12 volts hooked up to put out 12 volts. You need 6 volt size cables.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2019 at 6:46am
Tom it was converted to 12 volt at some time. I have taken every wire off of it. I will rewire it and run a one wire alternator with one big commercial battery. I rebuilt the battery box yesterday and pulled a good battery off of one of my other tractors. If it doesnt rain I may get to change the oil and spin it over today!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2019 at 10:34am
Got it fired up this morning, I built a new battery box and made new cables and got a new solenoid. Took the end of the starter off and the brushes look new. Using a temporary tank and switch. Turned it a few time till I got fuel at three injectors, gave it a tiny shot of starting fluid and off she went. Only ran it a minute because I have no water in it. I found a used preheater and thermostat housing this morning and their headed my way so next week I may be able to drive it around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2019 at 10:40am
I had pulled the tank to clean it so I rigged up this temporary tank. Don't forget about the return line to the tank. Ask me how I know:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 7:43pm
Found another Thomson yesterday. I hope the exhaust manifold is ok. Here's some pics for the Thomson freaks....
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 7:47pm
Thomson cane cutter at the same location.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 7:51pm
Thomson ditcher. Note the later model logo.
Edited by lowell66dart - 04 Nov 2019 at 7:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 9:31pm
That must be a cane cutter
This page was generated in 0.172 seconds.
