Off topic Gehl baler question
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: Off topic Gehl baler question
    Posted: 31 Jul 2019 at 2:34pm
There was an update a person could do to make an old Gehl baler start a bale easier. I have a 1600 model but I believe the update pertained to any of the older Gehl round balers. Does anyone know what that was and better yet have pictures? I think it had to do with welding something so that the belts were held slightly loose when the bale first started.
Wink
I am a Russian Bot
bauerd44 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bauerd44 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2019 at 4:47pm
Lonn,
I had a Gehl 1465 baler that I got a kit from the dealer to put what was called a "lagging belt" on the packing roller that originally was a smooth steel roller, and these rubber belting material helped grab the hay off of the pickup.  It still wanted to jam up if pushed too hard.
It seems to me that you could put something in to keep the top slide from tightening to belts too much.
Dale
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2019 at 10:07pm
Thanks, I read on some old archived forum that you weld angle irons somewhere to keep belts slightly loose then the bale would build and naturally tighten the belts. I'm unsure where these would be welded.
Wink
I am a Russian Bot
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 6:59am
I fixed this issue on my Gehl by replacing it with a John Deere!!!!  And before you say I spent big $$$, last year I spend over $1000 on all new belts for the Gehl which did NOTHING to help, and I spent $1200 on the JD baler!LOL  For once in a blue moon, I guess I got a little lucky, though now trying to get a bearing replaced on the JD.
Seriously though, is there a scuffer belt and is it in good shape on the bottom roller that pops up?  That's about the only thing that helps.....some.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 5:51pm
Never owned a Gehl, I assume its a rounder.  On my hesston, manual says to go across a few windrows, to start bales better...Wink
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 7:24am
The bottom table belt is the smooth style as are all the other belts. No textured belts. Had the same problem on an old worn out 1500 before. That baler took a slow boat to China. Dad's original 1500 he bought when it was fairly new didn't give trouble until she was well worn out. He custom baled for years with it. This 1600 was bought new by a guy who's dead now but he had a small farm and the baler really hasn't seen that many bales. I think I'll try starting the bale with the tail gate ever so slightly open then after it starts a bale I'll hit the lever to close it tight. That should tell me if the belts need slack when starting a new bale. Then, if so, I'll have to figure out how to keep the belts slightly slack to begin a bale without fooling around with the hydraulic lever.
BTW here is what I found on the net so far dealing with this issue but the details are lacking to me.
https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=implment&th=180707
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 7:29am
Now I found this from the same website archives
"Gehl made an improvement on those later. My 1450 didn't have it,but the dealer told me how to fix it. The 1475 has this improvement built in stock.
What it ammounts to is,you have to have the belts looser when you start a bale. Right at the front of the belt rack,up on top,weld a piece of angle iron just ahead of the front of it on each side where it slides on the top of the baler. Drill a half inch hole in each one and put a piece of threaded rod on each side with a nut on either side of the angle iron so you can back that rack off and loosen the belts in slippery hay. This gives you some room in the chamber to get more hay in to it so it has more hay to start." I wish I could see a pic of this improvement but I think I got an idea on what he's talking about.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 7:35am
Yes rounder. "go across a few windrows" sounds handy Ermm
The 1600 is old like 1980 or so. Hesston is a good baler too. My uncle had an old IH about the same age (built by Hesston) and it did good but my Dad and my uncle sometimes would bale together in the same field and the old 1500 Dad had could pack more hay in each bale vs the old IH. Not that it would make any difference to me in my small operation. The old Hesston had fewer bearing issues than the old Gehl for sure.
Edited by Lonn - 02 Aug 2019 at 7:36am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 7:52am
I should have taken a picture of what I meant last night......Though I didn't know your model number, and I think mine is different.  What I was referring to, is the roller that rotates counter to start a bale, ours is wrapped in a belt with some scuffer riveted to it.  Instead I flogged on that bearing until 9:00 again, but do finally have it off.
It is AMAZING how effortlessly that ancient JD starts a bale.  AMAZING I tell  ya!
Edited by Tbone95 - 02 Aug 2019 at 7:54am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2019 at 8:55am
Mine is a 1600 but Dad never had trouble with his first 1500 which is pretty much the same baler. The second 1500 was shot when he bought it so it was never good but this 1600 has seen very little hay in comparison.
Wink
I am a Russian Bot
This page was generated in 0.172 seconds.
