Allis Chalmers wagon running gear
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers wagon running gear
    Posted: 11 Jan 2019 at 1:57pm
Looking at an A/C gear that has 6 bolt hubs, no welds, and steering is very tight. Would this be a 6 ton gear/ Any ideas as to value? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 5:50pm
Should have a tag, LS rear axle.  Around here, any 6 ton gear would prolly bring around $4-600...
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 8:16pm
Like diyDave said, check it’s rear axle ID tag. It’s serial number will begin with either number “6”, or “7”, or “8” which denotes whether it’s one of the following;
“6” (6ton)= 601,
“6” (61/2ton)= 605.
“7” (7ton)= 700(early),701(later).
“8” (8ton)= 800.
All have 6 bolt hubs. Below is an ID photo for 700 or 701. In addition to ID serial number, look for stenciled model number “700” or “701” on outer side frames.
Value? Need more details. Depends on condition. You say steering is tight? Is it rusted tight(usual slop) or not worn out(few like this)? Any bent rear spindles? Bent or twisted hitch? Is adjustable reach pipe straight or bent? Have standard/extendable hitch? tires? And lastly, who’s all interested.
Edited by AC7060IL - 11 Jan 2019 at 8:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 8:39pm
last one I saw on an auction brought $600. that was a year ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2019 at 11:32am
Just curious - what model was it? Did you get it? If so, any photos &/or stories to share?
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2019 at 6:59pm
I haven't seen it since last Fall. I'm in Fl. for the Winter but have made it known that I am interested in it. When I said earlier that steering was tight - not because of rust, it's because of lack of hard use/abuse. Mismatched tires but overall, great condition. Has a gravity box full of ear corn on it now, our local tractor club has a show during 4th July time frame and we shell corn, thresh wheat, and saw logs - wagon won't be available until after that.
