MF Manure Spreader Apron Chain
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Topic: MF Manure Spreader Apron Chain
    Posted: 19 Dec 2018 at 7:36pm
I have a MF 3719 Manure Spreader that needs some slats replaced. It has the T-rod type chain. Anyone have any experience on how to disconnect the chain links in order to get things apart?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2018 at 8:16pm
prolly hafta do it from undernieth
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 10:11am
Jim, Pioneer welding or repair near Berne, In. has all kind of chain repairs can custom make slats for manure spreaders. Never taken T' type chains apart.
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 11:13am
No! do from on top.  Loosen the chain tightners ALL the way, get inside with your fence stretcher extended all the way, hook on one chain, PULL PULL as much as you can, in the center of the stretcher hooks you will have enough slack to  turn one link sideways so that you can get the top of the T thru its link!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 6:30pm
Easier to do from top, no stoopin, crawlin, and you won't get any sh!t in yer eye!Wink
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 6:35pm
If you got a loader, turn it on it's side and do it standing up!  You can check out the undercarriage for decay that may need repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2018 at 6:51pm
THANK YOU!  I wasn't looking forward to this job, but it needs to get done and your method sure sounds doable. Do these type links stretch over time/use? I've adjusted the chain to the max and it still has too much slack under the machine. While replacing the bent slats, I was going to remove at least one link. Shoup had the links and slats at reasonable prices.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2018 at 7:44am
"Stretch" is usually a little stretch maybe and a lot of wear and corrosion for sure.  Wear and corrosion makes every moving pin smaller and hole bigger.  Gain 1/16 of an inch clearance in a hole, every 16 links gives you 1 inch of slack.
