190XT turbo
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT turbo
    Posted: 21 Aug 2018 at 6:56pm
Looks like I am in need of a Turbo as the mounting flange is falling apart.
Need Exhaust Manifold and Elbow
My turbo has a TRW tag on it, but I can't read the numbers that good. I would like a direct replacement so my oil lines all work.
Suggestions for Farm use?
A&I?
Worthington?
Others? Someone suggested a Garret GT35
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 7:05pm
TRW  Valve Division
Model 370 F 70
Part 4021703
Charlie
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 9:18pm
I'm in the same boat as you are Charlie. I googled "is Garrett turbo made in USA" and what I read from a former employee made me check them off my list. They're not made in USA. I'm in no big hurry, so will be interested to see where this post goes.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 10:03pm
If exhaust housing is bad, I'm sure I Have one.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 5:45am
You can replace the housing? Where mine bolts to the manifold is getting holes that I have epoxied.
Along with that I am trying to trace where I am getting oil from, it seems to be coming out of the manifold? So the turbo is leaking?
The Valve cover I can't see a leak there.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 6:21am
I found out that Turbo was shipped on Gleaner G Combines with the 2900 series motor. Not sure how it ended up on this tractor.
I would remove the Turbo to check for leaks but I think the whole thing will fall apart when I do. Might be my fall project.
Charlie
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 7:13am
I can provide new or reman turbos. No knock off junk either.
rog 190xt x 3=? View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rog 190xt x 3=? Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 4:46pm
Hi I had the same leak on my 190xt I though it was the turbo leaking oil. It wasn't , it was a bad tip on a injector and was running fuel in and not spraying it and what I thought was oil was unburnt fuel .
Post Options Post Options   Thanks (0) Thanks(0)   Quote rog 190xt x 3=? Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 4:53pm
Those turbos came on 190xt's , 3 of the 4 190xt's I have has them on them . The other has the 2 bolt return line on it. You could use either if you have a tractor salvage yard by you . You can pick up the other lines pretty cheap . Not much call for them any more .
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2018 at 9:11pm
My turbo on my 190XT is in rough shape as well. It’s a Rotomaster tho. Never heard of them before
Edited by AllisChalmers37 - 30 Aug 2018 at 9:17pm
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2018 at 10:17pm
The oil from the manifold is likely oil coming past the valve stems at low idle. This usually clears up under boost and higher temps... the oil is burnt plus there is positive pressure holding the oil back..
