B crankshaft pulley replacement
The Consultator View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Consultator Quote  Post ReplyReply Direct Link To This Post Topic: B crankshaft pulley replacement
    Posted: 07 Apr 2018 at 1:27pm
I need to replace the crankshaft pulley on my B. Unfortunately, the set screw and lock nut are perfectly aligned with the nose weight plate. I can't reach the screw or nut without taking the plate off.
Dumb question: I don't have a service manual yet. which comes out first- the set screw or the lock nut?
I need to remove the front axle from the nose weight plate. I figure I might as well replace the bushings in front and, and replace the wheel bearing assemblies in the front while I'm at it.
Another question: Do I need to remove the grease points to disassemble the front end?
This is turning out to be a chore for just the crankshaft pulley. I'm also going to replace the radiator, water pump, thermostat, and temperature gauge since it's all apart anyway.
1939 Allis-Chalmers "B" restored in 2010- very good condition.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 2:44pm
Seems like if the lock nut actually had the setscrew locked you might have a problem removing the screw first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Consultator Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 2:52pm
That's why I ask the pro's...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 4:40pm
You might find something that helps if you have time to go thru a few albums. I never had a weight plate for a B.
https://public.fotki.com/DickL/
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Consultator Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 4:53pm
http://www.allischalmers.com/forum/uploads/17624/Allis_2c.jpg
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Consultator Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 4:56pm
The iron below the water pump inlet with the rag for a plug is what's giving me trouble. I'm calling that a nose weight plate, but I'm not shocked if I'm wrong. I currently have the fan, and adjustable pulley removed, but the crankshaft pulley nut faces that piece of curved iron just so, that I can't get it off without disassembling the front end so I can remove the rest of the pieces under the radiator mount.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 5:05pm
terminology I guess! You be talking about the pivot plate the has the pivot bolt welded in that is held in with four studs into the engine block. You will want to remove it for what you are doing. Not if you were just removing the axle.
You can see in the background a B with the pivot on and the axle off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Consultator Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 5:07pm
That's it! "Pivot Plate." Thank you for the help. That darn PP is in my way.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 5:48pm
A copy of the shop manual is on line at:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Consultator Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2018 at 6:02pm
Thanks Gerald!
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Consultator Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 8:29am
I got the newsed pulley on. Dropping/reinstalling the front end wasn't as bad as I thought. Everything went back together nicely. Now all she needs is a cleaning. The first antique car and tractor show near me in on May 5th. from what I've heard, I should be the only orange there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2018 at 9:41am
Good Deal! Have fun and take pictures.
This page was generated in 0.172 seconds.
