Salvage for Sale |
| Author | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
outbackfarm
Topic: Salvage for SalePosted: 24 Mar 2018 at 2:51pm |
I have a 4wd 6140 with an engine problem I cannot fix. Looking to sell for salvage.
| Sponsored Links | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Daehler
Joined: 23 Nov 2010 Location: Lexington MO Points: 1179 |
Posted: 24 Mar 2018 at 3:41pm |
If you were closer id be highly intrested. That looks too good to salvage, and a matching loader with fwa. Hope someone could get it going
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5199 |
Posted: 24 Mar 2018 at 4:34pm |
Does that use the 3 cylinder Perkins like the 160?
Edit: Just looked it up and it uses a Toyosha diesel Edited by WF owner - 24 Mar 2018 at 4:38pm |
Joined: 11 Sep 2009 Location: illinois Points: 91060 |
Posted: 24 Mar 2018 at 4:39pm |
copyrite1972
Posted: 25 Mar 2018 at 10:58am |
DON'T SCRAP IT!!!!!!
D15 Series II
outbackfarm
Posted: 25 Mar 2018 at 3:12pm |
I don't want to scrap it. I used it regularly until last weekend when the engine noise started. I just can't find the engine parts to fix it.
B26240
Posted: 25 Mar 2018 at 4:12pm |
I would think with the internet connected to the whole planet there must be parts out there somewhere to fix your engine, or someone knows how to swap in a Kubota or other engine. Don't give up so soon as that is a great size tractor.
lowell66dart
Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
Posted: 26 Mar 2018 at 10:19am |
What parts do you need? Rings, bearings, gaskets and seals are easy.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4079 |
Posted: 26 Mar 2018 at 3:39pm |
how about a perkins ad 3 or ad4 swap to bad eveything is across the country from me
outbackfarm
Posted: 26 Mar 2018 at 8:02pm |
would that fit a 6140?
outbackfarm
Posted: 26 Mar 2018 at 8:06pm |
I'm not exactly sure what parts I will need. It was running fine until last weekend. Then it stalled and now has a squeal in the engine then I crank it. It seems cam related . Engine seems to bind when one valve is in the down position. When I removed the rocker arm assembly it seemed to free up. So that's why I'm thinking cam bearing but I could be wrong.
WF owner
Posted: 27 Mar 2018 at 6:12am |
The camshaft would still turn with the rocker arms removed, so I doubt it's cam bearings.
lowell66dart
Posted: 27 Mar 2018 at 7:09am |
Do you have a way to manually cycle the valves to see if one may be bent for some reason?
Timberjack@48
Posted: 03 Jun 2019 at 4:41am |
Did you end up selling it?
Drok664
Joined: 13 Nov 2019 Location: Aurora, Indiana Points: 1 |
Posted: 13 Nov 2019 at 9:35pm |
What end up happening to your tractor
Jim.ME
Posted: 14 Nov 2019 at 4:45pm |
Hope he answers you, but he hasn't signed in since April 2018.
