Tilt Cylinder 500 Series Loader
gjac185 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gjac185 Quote  Post ReplyReply Direct Link To This Post Topic: Tilt Cylinder 500 Series Loader
    Posted: 04 Dec 2017 at 9:55pm
Hi,
I have a 185 with a 500 series loader.  Can someone tell me what the part number is for the rebuild/seal kit for the tilt cylinders on this series of loader?
Thanks in advance
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 7:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote gjac185 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 7:39pm
Thanks, I saw that posting but I was unsure from the description if the lower cylinder was the same as the tilt cylinder.  Thanks again for the clarification.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 7:52pm
I just go to Azdell Hydraulics in Mexico, MO and buy the Orings and wiper seal. Don’t need numbers just take old ones in and they will match them up. The seals and Orings are the same in both cylinders. This is much cheaper than buying kits
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 8:05pm
******I just talked to them today about those seal kits and they are $9.25 jobber and $12.xx resale.  My loader takes the same kits for either cylinder. I usually have the individual items around but that is a fair price..Dale
Doug-KS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug-KS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 6:59am
Are they the same for a 417 loader or are the cylinders different size?
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 1:05pm
The Kits should all be the same.  The tilt cylinders are the same except for the rods.  The 500 series rods are about 9.5 inches longer.  (and will have a tendency to bend easier) The ram barrels are the same.  The 400 lift cylinders are about 40 inches and the 500 about 46 inches.  (As I recall) Take the same kits as the tilt. I ordered some of the Baum kits today to see what they look like....Dale
Orangereborn
Dale Schafer
964  192nd Ave
New Richmond, WI 54017
715-247-3079
cell 715-781-2055 text
Orangereborn@hotmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug-KS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 1:31pm
Dale,  Let  me know how they look and how easy it is to replace them, and how they work.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote gjac185 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 7:13pm
Thanks guys,  I ordered a kit from Baum also, just need to be able to take the cylinder apart.  Any suggestions for a gland/pin wrench?
This page was generated in 0.127 seconds.
