CA Implements?
rustyorange45 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Topic: CA Implements?
    Posted: 27 Oct 2017 at 11:51pm
Did the CA have a rear mounted blade? Was it an Oxnard with CA width lift links or was it something else? Also what sickle mowers were available for one? I bought a Snap Coupler equipped CA and while it will primarily be used as a mower tractor with a Woods L306CA I was curious about what other implements I could use with it. What was available? What will fit? I seldom see CA specific implements for sale, while WD-WD45 implements are everywhere. Can WD-WD45 implements be used if you narrow the lift links? Thanks, Tim!
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 6:36am
The Oxnard blade comes with extra holes for changing the horizontal bar so it will fit the CA.  That is the only thing you need to change.  The pins come with quick/K keys but a lot of them I've seen have been replaced with cotter keys.
There were CA specific implements, but I don't know what they were.
I would think that you could alter the WD/WD45 stuff to fit.  It should be easy to do, especially since so many had just chains for use.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 6:55am
The CA belly sicklemower was the No. 7.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2017 at 7:27am
The Belly mower specific to the CA tractor, although it could also have B/C specific mounts was the #5. The #7 was a the first rear mount snap coupler mower for any snap coupler equipped tractor.
   As for Other CA specific implements, there was the #52 plow, #54 spinner plow, 2 disc disc plow, 4 disc tiller, #20 Disc, #30 Disc, #40 Disc, The two row Drill planter had 2 different hitches, Pin hitch & Snap Coupler, Front mounted Cultivators, Curved shank Sub-Soiler, 9 run All Crop Drill, Front mounted Dozer/Snow plow, 5 shank Coil spring field cultivator, spring tooth field cultivator, the above mentioned #5 sickle mower & Oxnard rear blade, farm crane and the rear mounted tool carrier, along with a 1 row Cotton picker. There also may be something that I don't know about. So if there is a farm job you want to do with a CA, there is a factory built CA implement for the job.
Edited by PaulB - 28 Oct 2017 at 1:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 11:00am
You can see some of the CA equipment in action in one of the old sales films. I think it's called A New Modern Farm Power Package.
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 12:26pm
Hi.    Hope the picture size is O K.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 12:38pm
CA and blade in action. Great combo.   R.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 3:29pm
Beautiful CA and B Ross! Dad has cultivators, belly sickle mower, 2 bottom plow, but is currently running a L306 belly finish mower. Great little tractor. A blade like that would be sweet. Also has a 3 point snap coupler setup with it.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 8:04pm
Thanks & God Bless
Dennis
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote rustyorange45 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 8:37pm
Really cool pictures of CA's at work! I have the Oxnard rear blade, nice to know it will fit my CA. Really cool picture of the CA crane, is that factory or homemade? Right now I have my mower on mine but with winter coming I think I'll take it off so I can use my blade if it ever snows. Thanks for all the pictures, good looking tractors and implements!
copyrite1972 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote copyrite1972 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2017 at 8:58pm
Thanks for sharin' the pics! Clap
My wife just happened by as I was ooogal'in them, she gave me a smack on the back of my head, and told me not to be lookin' at porn!!!! Wink
D15 Series II
cdon_FL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdon_FL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 11:42am
nice photos -- BUT DID THAT GUY REALLY PLOW A FIELD WITH A TOW-HEADED KID SITTING ON THE LEFT SIDE FENDER ????
Chris in NE Florida
kenbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenbob Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2017 at 6:49pm
I think there is a sub soiler for a CA on Dubuque craigslist.  I wouldn't mind finding a spring tooth around the KC area.
This page was generated in 0.097 seconds.
