Distributor Dust Cover Fit?
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Topic: Distributor Dust Cover Fit?
    Posted: 08 Sep 2017 at 9:45am
I ordered a Delco distributor dust cover for my Allis G (AB-186D). It doesn't fit. The inner diameter of the dust cover is about 1/32" too small. The distributor cap will not fit into the dust cover.
I may try to machine it in my lathe, hopefully without breaking it.
Has anyone else had a problem?
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2017 at 9:59am
Don't know where you got your cover from,but I've had good luck with the echlin line from napa,not the cheap performer line.echlin part number for dust cover is, ech-rr164.dist cap is, ech-rr145.hope this helps.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2017 at 10:19am
I would take it back before I started machining it.  Could be a simple error, but others may have the same problems if you don't let your supplier know.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2017 at 11:16am
looks like you purchased it from Steiner, let them know so the next guy doesn't have the same problem.
K-Mo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K-Mo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2017 at 9:57am
Dust Cover Update.
Machined the dust cover to a perfect fit. Good to go.
Source readily allowed a return, but not really economically practical time or dollar wise.
It all started just needing a rubber dust cover gasket. Opted for a new cover. I could have just used the gasket from the new cover, but a little machining and the new cover fits.
I am used to having parts issues. I commonly receive parts in a factory sealed box with the correct part number, but wrong part in box. I order a left and receive a right. I order a 2850 and receive a 2580. For me it's just another day.
If everyone has the same problems, the world has a problem. I hope it's just me.
K-Mo
This page was generated in 0.040 seconds.
