Starter for U or UC
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: Starter for U or UC
    Posted: 08 Aug 2017 at 8:19am
Does anyone kinow the part number or model for this starter, my rebuilder needs it any help would be great. Thanks Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 9:05am
Still need help
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 11:14am
You dont show a picture but originals were autolites.  Steve @B&B rebuilt mine, including rewinding the armature for 12 volts, he may be able to tell you something.  i could get the numbers off the tag on mine but wont be able to till this evening.
Edited by CAL(KS) - 10 Aug 2017 at 11:15am
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 11:23am
Dave, I looked on my UC and it doesn't have a tag.
The parts book says -
for the Continental engine Auto-lite # MAB-4003
and for the UM's Auto-lite MAB-046
don't know if that's any help or not
Joe
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2017 at 7:11pm
MAB 4046 on my UC
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2021 at 1:35pm
Hi guys I have found that a starter off a Moline ZA we'll drop right in. Only thing to remove is the solenoid. Delco 1107905- It has the right nose & Bendix
Edited by nowaktj - 19 Aug 2021 at 1:35pm
Pfouts Family Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pfouts Family Farm Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2021 at 3:07pm
MAB-4046 is a good number.  There are a whole laundry list of numbers when you get into the power units and crawlers which may have been subbed on to a U or UC over the years.  All of these units for the most part use the same parts.  If they use MAB-4046 it should get them on the right track.  If something isn't adding up, post or PM and I can dig up my list and give you some other numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2021 at 3:20pm
I agree the MAB number is the right number for an auto light starter. Since I've struggled to find an auto light I have been looking for a Delco replacement... And this one off a Moline is a perfect fit.
Mfam8 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mfam8 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2021 at 8:43pm
A Case D, DC, S, or  SC,  will all fit correctly. Also, they were factory Autolite. All you have to do is drill a new set screw hole, as they are clocked slightly different than a UM engine starter. Been using them for years, and this way you maintain the correct look for the tractor as well.  THere is also one on EBAY right now for an SC, I noticed.
Edited by Mfam8 - 19 Aug 2021 at 8:46pm
This page was generated in 0.034 seconds.
