Gleaner F2 Throttle Cable
matador View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F2 Throttle Cable
    Posted: 23 Jul 2017 at 2:20pm
We need a new throttle cable for our F2 (Our machine has the 433I engine). Does anyone know what length of cable we need, and does the cable separate from the handle assembly in the cab, or do we have to purchase the whole assembly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2017 at 2:27pm
Last one I bought from Agco it just had the wire , you had to string it through the coil pieace, not fun
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2017 at 2:42pm
two types - it is available as a wire, or the cable , or the entire assy - or the late models used a large cable in lieu of the lawn mower type.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 11:38pm
Matador, if you guys need any help locating one, give a call, I am sure dad would love to hear an update.
Did the wire break, and the sheath is fine, or is the sheath messed up too?
if you replace just the wire, we have had good luck sharpening the end so it doesnt catch, and then as you feed it in, coat it with anti-seize.
You will need to be removing the cab side panel and sit on the tire for this adventure. might need to feed the wire through the front console door. Having two sets of hands will help.
Edited by GM Guy - 30 Jul 2017 at 11:41pm
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 10:35am
Sheath seems fine. The problem is that the wire itself seems bound in there. Moving the throttle in cab does nothing- the machine stays at idle, and handle itself pops back to idle when you're not holding it. We're planning to pull the cable out of the sheath, bathe it in oil, and try feeding it back in, unless that causes a problem
As for the machine itself, so far, so good other than one major problem. Over the beater, part of the sheet metal broke off on the top, causing chaff to be spewed all over the engine. We noticed it right away, and there was fortunately no fire, though we did use the extinguisher on it. We've fabricated a new piece, so that's good to go
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2017 at 4:55pm
due to the open hood design on a F2, my vote is the cable is slightly rusted at the first low spot downhill from the engine end of the cable.
I would spray some PB Blaster down it, and try to wiggle it from the engine side.
If its being stored outside, maybe put a truck mudflap over the injection pump and cable so that snow does not set on it, as I am sure Wyoming meets or exceeds a Northwest KS winter, and snow can blow into all sorts of places.
