1948 Allis B Water Pump
Eldon in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon in MN Quote  Post ReplyReply Direct Link To This Post Topic: 1948 Allis B Water Pump
    Posted: 18 Jul 2017 at 7:44pm
The water pump on my B Froze up. So I took it off the tractor today. How does one get the pulley off. I am not the most  gifted mechanic but can usually get by enough to keep it running. What are the two bolts with nuts sticking out of the pulley. Do I need to remove them or are they for some type of pulley adjustment. Also, from the pictures I am copying can anyone tell me which new water pump to order. When looking at the after market pumps I see several options, some say with sheet metal pulley so say with bypass plug and others with back plate and gasket. If there is a shop I can just send what I have to and they remove the pulley, rebuild the pump and reinstall the pulley and mail back I am good with that also.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 8:39pm
Take the 4 bolts out, pulley should come off with a bump on the center.  The 2 bolts w/nuts are to adjust the pulley width, shouldn't have to move them if you have an alternator or generator.  Call OK Tractor for new water pump and Jim can answer any questions about different water pumps.  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon in MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 8:42pm
Will do thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 8:43pm
when you have the pump off, look at the back and you will see the "plate"... if you don't get a new one, you need to remove the old and will need a new gasket..... the bypass is for the D10-12 tractors--- you can plug that if you get that version..... I have tried to "rebuild" and generally you can buy new for cheaper.... labor is expensive.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 9:17pm
The shop manual that I have on line for the G, B, C, and CA might help.
http://www.geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2017 at 9:57pm
Check e-bay, I purchased a new (clone) water pump for $69. They are not worth rebuilding as requires special tools.
This page was generated in 0.073 seconds.
