HD5B Battery Size |
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2075 |
Topic: HD5B Battery SizePosted: 18 Jun 2017 at 9:13pm |
What is the correct battery size for my HD5B dozer ?
Thanks & God Bless
Dennis |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3296 |
Posted: 19 Jun 2017 at 6:56am |
Originally they used 2 6 volt batteries. Haven't got to that point with mine yet, but was told a good 1000 amp would do it. Think I will probably get a battery like is used in a semi truck, the kind with the screw on top posts. Around here I can get them cheaper than a big car battery.
DougS
Posted: 19 Jun 2017 at 7:15am |
Whatever you get, make sure it's a heavy duty battery. High CCA but with many closely-spaced plates is inviting premature battery failure.
johnkc
Posted: 19 Jun 2017 at 8:33am |
The group 31 truck battery with 925 to 950 CCA have been working/lasting good for me.
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42114 |
Posted: 19 Jun 2017 at 8:53am |
HMMMMM - Seems since I first bought my HD5G in 1972 the battery issue (as the 2 - 6V ) that came with the machine were bad - I took the battery out of my 66 Chev truck .
WORKED - so since then I have bought GROUP 34 / 78 or just 34 group since . I use the same battery in my 715B, 460 IH Utility tractor, Skid loader, 76 GMC tandem, 66 White Tandem , 411 Adams grader, 2 in my FD5 to get 24 volt, and in all the pickups . Used 2 in my 6.2 Diesel pickup and 2nd one in snow plow trucks . I buy 950 Amp size with 5 or 6 year warranty, with about 15 batteries in service if one went bad just swap them around - take bad one back and put it in service Had no failures from vibration in equipment - seems most lasted 4 years minimum - not having them on maintainer and setting was the worst . So one high Amp 12 volt will work - that leaves the other battery box empty for grease gun , either can , mickey mouse ears, and tow chain , hammer and pair of pliers Edited by Coke-in-MN - 19 Jun 2017 at 8:54am |
DougS
Posted: 19 Jun 2017 at 9:07am |
How does that work for you in a Minnesota winter?
wayneIA
Joined: 17 Oct 2009 Location: Waverly, IA Points: 268 |
Posted: 19 Jun 2017 at 9:23pm |
I use a 950 amp like Coke and my HD-5 will start in the winter with some smelling salts just fine. The coldest I've started mine is around 15 degrees, needed to move it to get something out.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4801 |
Posted: 19 Jun 2017 at 10:11pm |
About 10 years ago the daughters Kia car had a battery go bad when she was shopping. She batted her baby blues at some male that was glad to help her get and put a new battery in. Gets home and has to show me,small Delco battery but was a bit to big one side so hold down didn't fit. She bugged me until I got her a battery that the hold down would fit.
That Delco was close when I needed a battery for the HD 5. Like Coke I am always moving batteries between equipment,so figured it would not last in the crawler long. Ended up staying there for better than 5 years could of been 7. Probably helped it was not run a lot of hours to shack it apart,but was good after sitting 4 or 5 months at a time.It was enough battery to start the 2-71 even though it was not a big battery.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34439 |
Posted: 19 Jun 2017 at 10:23pm |
If the 2-71 is good, it doesn't take much... I started an HD19 with a 6-71 that had sat for several yeaars and all I used was just a little bitty jumper pack... I couldn't hardly believe that but there it ws winging the engine over and started right up.
In my HD5, it just gets what ever battery is available at the moment. mostly some old car battery. |
DennisA (IL)
Posted: 19 Jun 2017 at 10:46pm |
Thanks for all fhe replys. I went with the optima d31m. It's the right group size and has the cca.
Thanks & God Bless
Dennis |
DougS
Posted: 20 Jun 2017 at 4:46am |
Optima works. I would have suggested an AGM but I didn't think you were in the mood to spend that kind of $. Actually an AGM is a good choice for rough service. The mats between the plates tend to keep the cells from shorting out.
DennisA (IL)
Posted: 20 Jun 2017 at 8:15am |
AGM batteries is about all I use any more. As the lead batteries need to be replaced I get the AGM's. I don't have the issues of bad batteries any more. Whatever tractor I want to use the battery is always up and ready to go. The oldest one is in my CA. It's 6 volt and over 12 years old now. They are pricey but seem to last longer than the lead ones and have more cca. Course I don't have maintainers on them either. Only one shed with electricity and most of the time the tractors are not parked there.
Thanks & God Bless
Dennis |
