Dual tire pressures
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Dual tire pressures
    Posted: 28 May 2017 at 8:13pm
Just wondering what pressure I should be running on the duals of my WD45.  The main tires are 13.6 x 28 but the duals are 14.9 x 28.  Since the duals are larger, I think they should be run at a lower pressure.  Am I right?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 9:04pm
I would run lower pressure in the duals because of the size difference.  I run 15 lbs +
in radials on a big tractor. Your tractor is light but bias tires so maybe 15 lbs in the duals and 20 lbs in the mains.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 10:56pm
15 lb inside and no more that 10 in the duals.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 12:24pm
I'd prefer that the larger tires were on the inside...but yes, lower pressure on the outside, especially with the big tires on the outside
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2017 at 4:01pm
Why do you have larger tires on the out side? That's hard on the axle. I've always set up the tractor to have 20 pounds inside and 14 on the out side
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2017 at 2:14pm
Running 2 different size tires on the same axle makes the tractor harder to move. The larger tire will drag the smaller tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2017 at 9:00pm
I bought the tractor that way.  It will probably stay that way until I win the lottery, then I could buy 4 new matching tires!  None match now and some do look iffy...
This page was generated in 0.071 seconds.
