190
showcattle75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Topic: 190
    Posted: 17 May 2017 at 4:48pm
Final drive and pd. I need to change the oil in my final drive but my manual dosent tell me where to refill. Also when my pd is in the natural position the tractor still moves forward I can hold it with the breaks is there something I need to look at ?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2017 at 9:32pm
Pump it in the check plug holes on side of housing just below axel level.
Should set with hot oil. Will want to pull with cold oil. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 11:16am
I pulled plugs on final drive. If you stand behind the tractor the final drive on the right hadbout what it sould be in there. When I pulled the plug for the left side all the fluid in the trans mission came out amd I could here a hissing noise from about the left final drive. I thought the final drives were seperate from transmisson or is this normal ?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 11:39am
finals are separate.  hissing noise might be vent on transmission because the axle cap has come off allowing trans oil into final.  you will need to pull the rear housing and reinstall cap inside.  I suppose the seal could be bad on the pinion shaft as well but more likely the cap came off.
this is what it looks like inside.  you can see the RH cap
Edited by CAL(KS) - 23 May 2017 at 11:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 2:54pm
Will it hurt if I fill with hytran until I split tractor ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 6:04pm
It probably is just an axle cap and all you have to do is pull the rear 3 pt housing off and you,ll se it laying in there, if you don't have time for that and need it now, fill it with fluid and run it,its probably been like that for years , I bet theres some out there that the finals haven't been checked and are the same
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 7:41pm
Ya itsmy grandpas tractor and he passed away awhile back just now gettting to fix it up. So idk hoe long it been since final drives were check. Should I pull pto shaft out first before removing the big cover ?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 8:57pm
If you keep the trans full it will fill the axle and you can have an axle seal leak. Had that on ours when I put the cap back on and got all the fluids right the axle stopped leaking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 9:53pm
It says when I put pto shaft back in I have to split tractor. Or am I reading it wrong
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 8:23am
No, take PTO out and in does not require split, just drain PD along with rear end.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 4:08pm
Ok I just filled both final drive so I can get hay mowed and baled. Then I plan on splitting the engine from trans to pu rear main seal in. Also 5th and 6th falls out. And in wanting to get that fixed. What all will I need or should replace while its apart
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 4:23pm
my photo from above was from when i fixed gear jumping on my tractor.  everything you see has to come apart.  fix anything that needs it while your in there.
Edited by CAL(KS) - 24 May 2017 at 4:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote showcattle75 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2017 at 4:25pm
Ok thanks cal
