190 xt wont turn over
showpig68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote showpig68 Quote  Post ReplyReply Direct Link To This Post Topic: 190 xt wont turn over
    Posted: 14 May 2017 at 9:50pm
have a 190 xt gas, running fine shutoff to add some hydralic fluid, went to start it and the starter just kinda thumps and fan blade turns about 1/4 turn and thats it.  figure it is the battery but it started fine earlier.  any other ideas?   seems odd batter would go bad that quickly but i guess possible.
thanks!
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 9:38pm
Worst case...hydro locked.   Coolant in a cylinder
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 9:50pm
Clean and tighten the battery cables. If that doesn't do the trick check the battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 12:32am
sounds like starter replace/rebuild time. let it cool and see if it works better
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 1:51am
I'd put on a set of jumper cables and see if that will start it.
