Bell housing seal. Need help!!!
bluewavecaptain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bluewavecaptain Quote  Post ReplyReply Direct Link To This Post Topic: Bell housing seal. Need help!!!
    Posted: 05 May 2017 at 3:06pm
Can I get some assistance? We have a 39 RC I'm currently rebuilding the bell housing and transmission on. Just doing a thorough cleaning and all new seals. There's a cork seal that sits behind the throwout bearing that I need to replace. I did some research with mixed results. The shaft has a spiral cut in it to push oil back into the belt pulley gear compartment. Some forums have replaced the seal with a modern press in seal. But a few others wrote that it has to be replaced with cork because of the spiral cut in the shaft. Could you guys help me out? What do I do?
Charles Nelson
Charles(Two Rivers,WI)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 8:52pm
If the original cork seal is not available, you can buy a "speedi sleeve" to press over the spiral grooves in the shaft and use a rubber lip seal.
http://www.skf.com/group/products/seals/industrial-seals/power-transmission-seals/wear-sleeves/skf-speedi-sleeve/index.html
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 8:55pm
There is no reason why a lip type seal won't work.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 9:11pm
It won't with a spiral grove cut in the shaft. The grove will EAT the seal up.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2017 at 9:50pm
speedy sleeve or fill in grooves with JB weld or such and sand down smooth
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 6:26am
Cork worked for the first 76 years.....
Edited by littlemarv - 06 May 2017 at 7:33am
The mechanic always wins.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 7:31am
Installing the lip seal is a little harder than just buying the seal. The old seal base will need to be machined out or purchase a seal holder from a D 10 thru 15. I set up and milled out a few so the D 10 thru 15 rear lip seal would press in. I made a fixture to work on my one rotary mill turn table.
I just installed one a couple weeks back on my one C. I did use a speedy sleeve. It gets kinda spendy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bluewavecaptain Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 7:44pm
Marv, where'd you find the cork seals?!
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2017 at 10:20pm
I just called my local Allis Chalmers dealer. Call Niemuth Implement in Stetsonville first, then Area Equipment in Thorp. They used to stock lots of Allis parts, but unfortunately, the last time I called for something, they had gotten rid of their stock. They can still order parts in, though. They should be able to help. I think the part number is 7020860. If all else fails, contact Norm Meinert here on the forum.
Edited by littlemarv - 06 May 2017 at 10:35pm
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 4:09am
Try Brenda at Sandy Lake Imp, they are a sponsor of this site.
check under the parts tab at the top of the page.
Edited by Gary in Texas - 08 May 2017 at 3:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bluewavecaptain Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2017 at 7:09pm
I tried reaching out to Norm. I didn't get a response yet.
This page was generated in 0.103 seconds.
