1941 Allis B timing problems |
Revilo
Topic: 1941 Allis B timing problemsPosted: 06 Apr 2017 at 12:43pm |
Hello from England!
I've recently bought a 1941 Allis B. The guy I bought it from told me he'd never had it running. He also said it had a replacement mag fitted. When I got it home I found the mag to be in poor shape so I fitted a new coil and condensor. I'm happy there's a spark but I'm confused as to how to time it. The mag itself - Fairbanks Morse K4B. There's a fibre gear that's confusing. It has an A (which I understand is anticlockwise) and a C which I've timed it to (which is clockwise). On the pictures I've seen of these gears the A and C are fairly close together. Mine aren't, they're about 9am and 2pm, which worries me as to the mags suitability for this engine. I'd appreciate some advice. Regards, Andy |
Joined: 11 Sep 2009 Location: illinois Points: 89248 |
Posted: 06 Apr 2017 at 10:25pm |
most of the mags I have seen have the A and C maybe 20-30 degrees apart on the gear.. I don't know much about YOUR specific mag.. that might be the difference. If you have the gears lined up as expected, you will get a spark........ if the timing internal is off, it will not spark....... since yours sparks I would assume it is OK and install on the tractor and rotate the motor by hand and see that you "spark" at the TDC mark on the crank ( top dead center)... the mag should go to advance ( fire mark) as RPM increases.
im thinking the FMK was an older design used on the WC tractors ?? 1930s ? Edited by steve(ill) - 06 Apr 2017 at 10:31pm |
Posted: 06 Apr 2017 at 10:28pm |
Revilo
Posted: 07 Apr 2017 at 2:15am |
OK, thanks. It'll be Monday before I get chance to have a go at sorting it. Cheers.
