Wd45 stalls out under stress
Mountain goat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 stalls out under stress
    Posted: 28 Mar 2017 at 5:39am
I can't figure out if the issue is fuel or electrical I cleaned the entire fuel system and the points got it to run great in neutral. Any ideas
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 6:21am
Rust in the tank? My WD would run after setting-maybe 5 minutes, then die. Wait a while, it would repeat! Found out rust chunks were mostly blocking the inlet inside the tank.
Edited by omahagreg - 28 Mar 2017 at 6:22am
Greg Kroeker
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 7:05am
Check ignition timing advance weights and spring under the points plate and then check the governor weights. You can also open up the main or load jet by one turn and see if that helps also.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 7:11am
is your tractor stuck between 2 gears?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 7:29am
Mountain Goat... that's undoubtedly one of the shortest problem descriptions you could describe. Troubleshooting a problem with a RUNNING engine is best if one makes more observations known, and also identifies what was attempted.
One of the very first things that will stall an engine, is applying too much load. Another, is applying a load before the engine is warm enough to run. Having improper mixture, plugged up air filtration, plugged exhaust, leaky intake or exhaust manifold, poor fuel, improper fuel level or plugged carbeurator, weak battery, bad coil, stuck spark advance mechanism... worn carb throttle shaft, governor linkage problem, sticky valves, hydraulic pump unloader mechanism failure... Here's a really simple one: Water in the gearbox, and ambient temperature below 32F... frozen gears... just like stuck brakes...
Can you tell us more about what youv'e done, mebbie a bit more example of how much stress is required for it to stall... what does it sound like, what color is the spark plug insulator once it stalls?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 8:16am
Brakes rusted in the ON position?
Like Dave says, we need more info.  Where in WI are you located?  There's all kinds of help all over the state.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 5:55pm
Sorry my first time I made several attempts to get that post up ok it runs great in neutral idling and high Rev but when I go up a hill or try to get a load of gravel in the bucket it starts to misfire and pop but keeps going I've cleaned the entire fuel system except the tube in carb couldn't get it out but used carb cleaner and air gastank had rust so took it off cleaned it cleaned points and retimed it   2 turns out on carb runs best brakes good air cleaner good
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 6:54pm
The tractor sat outside for a year or so untouched before I got it.at first it would only run a few seconds because rust was plugging the inlet in the tank so I cleaned it then it would run but it miss fired alot then I cleaned line n card then started both jets air and gas 1.5 turns it started warmed up I moved the thottle n it died so I turned fuel out to 1.75 stared ran ok also noticed that the the idle screw was all the way in. Anyway it ran better still to much missing so then I moved the distributor until it leveled out with barely any missing and the idle speed went up then put it on high Rev and it missed slightly so I left it on high Rev and adjusted the fuel until it ran smooth now it runs great until I go up hill or scoop with it the brakes don't stick although I have driven with them locked 1 time the shift works great no slipping out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 7:24pm
I might suggest taking the hose from the air cleaner to the carb off and try it. Maybe the air cleaner is plugged? Or put your hand over the top of the air cleaner pip when running and see if that makes any difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 7:43pm
Thanks for the advice guys I'll try to narrow it down next time I go to the tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 7:50pm
Worked on the wd45 yesterday checked the plugs n wires took the air cleaner off n it ran the same it runs good until I go up the hill and it starts surging runs good for 3 seconds then misfires for 3 seconds then good then misfire I'm starting to think it's a governor problem. If I hold the rod coming off the carb it revs up n runs smoothly and it tries to push the rod back. If I move the hand throttle lever I can move it about 1 inch before it moves anything else. I've seen posts on this did anyone ever figure it out
GregStremel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregStremel Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 8:10pm
Try brand new spark plugs? We used to have a problem like this. The Champion pugs looked good. We put new Autolite plugs in and problem solved.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 8:36pm
My d 14 had a similar problem . Going up hills on the road it would start missing and cutting off.It had not been run much in several years. Cleaned carb and it cleared up.The tude in the carb needs to be cleaned also .
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 4:49am
is it a magneto or coil?  if it's a coil maybe it's starting to go.  generally it takes a bit to get the coil hot and it just shuts off and won't start till it's cooled down.  but I've found parts generally fail in there own way, just to mess with us...lol
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 6:35am
I agree with replacing the spark plugs. Mine did the same thing going up a hill. I did everything suggested and nothing changed. I finally replaced the plugs with new ones. Problem gone. Don't clean them-replace them. Good luck!
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 8:15am
The plugs potentially could be the problem and all 4 at once makes it a little less logical but strange things happen. Sounds more to me like the fuel mixture is getting lean. At high idle with no load the throttle plate is just barely open more than at low idle and this means most of the fuel is being supplied through the idle jet. When the load goes up the throttle plate opens more thanks to the governor trying to maintain RPMs. The opening of the throttle plate means more air and more air needs more fuel. The gas for this increased amount of air is supplied by the main metering jet. I suspect this needed fuel is not being supplied for some reason. I think for sure it is not making it to the combustion chamber at the right time and in the right amounts to make the power to keep it running. I'd open the main jet about a half a turn. I have seen times If it has an idle mixture jet that is open too far you have to run the main jet closed up a bit to get it to idle at low speed. Those old carbs just kind of "spill" the gas into the air stream. They can do a great job but they need to be clean enough spill the right amount and todays gasoline can clean junk out of passages and drop it into other passages.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 8:46am
Bad condenser maybe?
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 10:18pm
Coil
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 3:53am
could also try running it at night that way ya can see if there is any spark arcing, like a hairline crack in the distributor cap or bad wire, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mountain goat Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 8:44am
It has a coil.I cleaned the carb again I'm pretty sure it is not a fuel problem or governor.I took the plugs out and cleaned them.their champion 1 and 3 were flooded I put them back in it idled great went up the hill good at first then started it's stuff again the farther I went the worse it got I think it is electric problem
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 9:14am
How much fuel is in tank might not be enough to push fuel to carb if going up a hill try putting more gas in it and cleaning the carb since it sat for awhile plugs are also a good idea autolite 295 work good for me avoid champion plugs good luck getting it up and running good
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 9:16am
Replace the plugs! Don't clean them. I believe I put Autolite 295 plugs in mine. It's a cheap try and new plugs never hurt..
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 11:09am
i would change the plugs ,,,,and wires,,,,and the coil wire
if you had 2 plugs fouled they are not firing under load,,,,change them all
my .02
ocharry
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 11:36am
I think I would try new points and cond. find ecklin or standard points and cond. There are a lot of cheap brands out there and they are junk.
turbocharged
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 2:15pm
Champion plugs just don't work good in an AC 201 or 226 engine. Like was said before, buy yourself a set of Autolite plugs. It will make a world of difference!
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 3:28pm
I had a very similar problem with a D15. It would get worse as it ran. It Was The COIL!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 8:10pm
Champion tractor plugs are junk and won't clean properly no matter what you do to them. Get rid of them.
Gerald J.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 6:41am
I stall out under stress too! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 8:20am
If the plugs are wet coming out they're not firing correctly. Most folks just don't have any luck with Champion plugs (including me) Some folks don't have any problems with the Champions. Put a set of Autolite 295's in them and then see how it runs. That's  probably the issue, cause' if the Chimpanzes are fouled, its getting fuel. Take them out the throw em' in the round file. I never try to clean spark plugs unless they are new and got fouled because of a flooding issue or setting up an engine or somethin'. Older used plugs, in the trash....  Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 9:50am
Lots of Champion tractor plugs have an internal series gap to cause the coil to generate a higher voltage because Champion presumes ALL vintage engines are oil burners.
That's one problem and the other one it appears that the ceramic is porous so that carbon soaks in and standard cleaning like running normally or with a surface abrasive powder doesn't clean them.
Good reasons to avoid Champion tractor spark plugs.
Gerald J.
This page was generated in 0.067 seconds.
