Belly grader blade for D17 |
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6109 |
Topic: Belly grader blade for D17Posted: 14 Mar 2017 at 8:32pm |
Hey- anybody have pictures of a belly mount grader blade mounted under a D-17? I need something that'll flatten and grade better, and figuring I'll be fabricating it, but could use some examples...
Ross D.
Joined: 02 Sep 2013 Location: Erin, Ont. Points: 339 |
Posted: 15 Mar 2017 at 2:11pm |
Hi. In Aug. , 2008, at the A C show in Portland In., there was an open stationed 190 XP on display with an underslung grader blade assembly. Boy-o-boy, was it nice. Unfortunately, I can not find my pictures from that show. Perhaps someone else may have a picture of it. The gentleman who displayed it said that it belonged to his son and that he used it in the landscaping business. I think they were located to the north of Portland ( towards Ft. Wayne ). Ross D.
john(MI)
Posted: 15 Mar 2017 at 11:38pm |
I'm curious why a snap coupler blade won't work? One in good working order can be adjusted to about any angle you could want. They are heavy enough to dig deep, and with good hydraulics you can put it at any height to level off. Just going thru my mind what all you could need to grade.
DaveKamp
Posted: 16 Mar 2017 at 1:11am |
I'm looking for one in the belly, because the blade I have behind (or any blade behind) will dig IN when the front wheels climb up over a lump, and when falling down the other side, drop dirt on level ground.
I want to knock the high spots down as they pass between the front and rear axles. I also want to be able to lean and swing the blade to use it for grading, like a speed maintainer.
Ross D.
Posted: 16 Mar 2017 at 9:42am |
Hi Dave. I like grading with the snap coupled grader blade; but, understand your comments on the frustration that you encounter. Here is a picture of a possible solution. If you could find a nice 'D' grader, I am sure you would enjoy experience. They do a good job and are a lot of fun to operate. This picture is of my 'D Special', with Calvin Schmidt grading Justin Biebers laneway in Stratford, Ontario.
Ross D.
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54725 |
Posted: 16 Mar 2017 at 10:40am |
And a D grader, late models, at least, use same motor, as a d-17...
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2584 |
Posted: 16 Mar 2017 at 10:51am |
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 16 Mar 2017 at 11:13am |
That grader looks like it'd be a lot of fun to operate - I could use it on my lane! I can just hear my wife's response, though: "You bought WHAT??!!??"
Dave
WC, CA, D14, WD45
Bob-Maine
Joined: 11 Sep 2009 Location: Central Maine Points: 922 |
Posted: 16 Mar 2017 at 2:43pm |
Dave, Maybe more practical than the HD-41 that was for sale in central Mass a few years ago. Bob@allidowneast
Stan R
Posted: 16 Mar 2017 at 3:22pm |
Mikez
Posted: 16 Mar 2017 at 6:32pm |
Did you see in the link Stan put up, grader Greg, it's a stretched out 700 series garden tractor with two rear drives. Interesting looking
Acdiesel
Posted: 25 Mar 2017 at 9:12pm |
CTuckerNWIL
Posted: 25 Mar 2017 at 9:22pm |
[TUBE]ZMXJvBZC52Q[/TUBE]
ac fleet
Posted: 25 Mar 2017 at 11:23pm |
Use the idea that Farmall cub uses on their under blade!----simple made and does nice work!---I have one under one of my cubs right now.
You will do good with the under mount! Grader in the above pic. looks like the BD-3 that I once had! ---DETROIT 3-71 engine!----I also had an Allis 45, it had the 516 engine in it---now thats a hoggin machine!!! LOL!!! thanks; ac fleet |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 26 Mar 2017 at 8:56pm |
ac fleet
Posted: 26 Mar 2017 at 10:29pm |
Ya want pictures of my cub setup???---- Will gittum tomorrow and get them posted up for you.---It's an idea that could be adapted to any size blade or any color tractor.---Just scale it up to whatever size you need! thanks; ac fleet
ac fleet
Posted: 27 Mar 2017 at 8:07pm |
Wes (VA)
Joined: 12 Sep 2009 Location: Elkton, VA Points: 510 |
Posted: 27 Mar 2017 at 9:33pm |
I have an early D grader that I'm trying to sell. The engine is tight, needs tires.. It may be easier to put a blade on your 17. :).
DaveKamp
Posted: 28 Mar 2017 at 6:48am |
Wow, Fleet- that's a cool setup... yes, simple, and perhaps a little on the lightweight side, but for a Cub, that's to be expected.
Some variety of that was kinda what I had in mind. The hydraulic version above looked right, but the pictures were a bit small for details. A Grader... yeah, aside from the long wheelbase maneuverability, it'd be nice. I'm the kind of guy that'd have one just because I could, but it wouldn't be the optimal worker for what I'll be working down... but hey... more pictures!!!
DaveKamp
Posted: 28 Mar 2017 at 6:49am |
Charlie- for some silly reason, I can't get your video link to do anything but turn blank... can you re-post it as text?
Ted J
Posted: 28 Mar 2017 at 8:31am |
Thanks for the pics Sonny! Gives me a couple of ideas.
ac fleet
Posted: 28 Mar 2017 at 11:36pm |
Ted!---You could use this as an idea to work from!---Just scale it up to whatever weight your tractor needs!---the idea can be adapted to any color or size tractor.
Nother' idea I have is to start with this STYLE setup,---THEN add a long cylinder on each side for seperate control of the blade---- angle could also be a cylinder on a third valve! ----I got all kinds of ideas!!! LOL!!!! If the cub had aux. hyd. ( which they don't) I would put each side on a valve/cylinder to control the blade!---for its size it does great job the way it is, just gotta take light cuts! thanks; ac fleet |
