D14 Fan and Radiator issues |
| Author | ||
AJ
Topic: D14 Fan and Radiator issuesPosted: 08 Mar 2017 at 8:59pm |
Anyone have problems getting a new radiator to fit in a D14? I have a brand new radiator I'm trying to put in a D14 but the fan don't seen to clear the radiator. I had the stock fan on first. Now I grabbed a C fan and it still barely hits still. Are these new radiator crap?
![]() Edited by AJ - 08 Mar 2017 at 9:00pm |
Can't fix stupid
| Sponsored Links | ||
dawntreader74
Posted: 08 Mar 2017 at 9:15pm |
had the same thing on a 45' i took an marked it nice an cut some off with cut off wheel' an took a mower blade balance tool an balanced it before i put it on' worked good' 7 years now.
LeonR2013
Posted: 08 Mar 2017 at 9:21pm |
Good idea downtreader!
dawntreader74
Posted: 08 Mar 2017 at 9:23pm |
THANK'S LEON'
AJ
Posted: 08 Mar 2017 at 9:38pm |
Yea, I'd rather cut the fan then start cutting into the radiator supports. I had a thought to just out an electric fan on instead. Anyone ever do that?
Can't fix stupid
dawntreader74
Posted: 08 Mar 2017 at 9:43pm |
money ahead to trim fan' also your battery will stay up to''
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54723 |
Posted: 09 Mar 2017 at 5:04am |
New radiator may be a fits all, works on none. Also check the fan, itself, there is an adjustment on the belt, that shifts the fan to and fro, IIRR...
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 09 Mar 2017 at 5:12am |
I was wondering about the fan being adjustable. When I got a new radiator for my d17 it didn't fit at first glance and I had to run that day so I didn't see how the mechanic I had helping me got it to fit while I was making a parts run. But then I looked at it later nothing looked cut. Edited by Dan73 - 09 Mar 2017 at 5:13am |
ac160
Posted: 09 Mar 2017 at 5:40am |
I put a new radiator in the 45 and had the same problem. I trimmed the radiator instead of the fan. No problems with it.
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 09 Mar 2017 at 6:06am |
Only thing that shifts is 1/2 of pulley ,NOT THE FAN. Not very often I install aftermarket radi. that dose not require a adjustment to install. |
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 09 Mar 2017 at 6:15am |
OK, I'd be trimming the fan shroud.
reasons 1) only two shroud sides to trim, fan has 4 blades, so 1/2 the work 2) trimming fan blades needs to be precise( balance) 3) should has pop rivets to the 'correct cops' will know anyway D-13#3 has a modified shroud as does the forklift.. I suppose it's really a coin toss ,maybe do what's easier and needs less bandaids ? Jay |
TimNearFortWorth
Posted: 09 Mar 2017 at 8:37am |
Urge anyone seeking a radiator replacement on the smaller A-C's contact Tony w/ Tony's Tractors on this site.
Tony went through plenty clarifying which/what/how on fittings from different supply sources over the years and can typically get what you need with less headaches. |
Posted: 09 Mar 2017 at 5:58pm |
OK, I stand corrected, remember I said IIRR...
