D17 Series 1 PTO Lever
willard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote willard Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 1 PTO Lever
    Posted: 30 Jun 2010 at 10:32am
My D17 PTO lever does not "catch" or turn on and off the PTO anymore. I seem to remember that there may be a roll pin inside that needs to be replaced to fix this problem. Can anyone give me some insite? Thank you for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2010 at 10:37pm
Yes, it is quite possible that the roll pin needs replacing.  Can be accessed by the panel on the right side of the torque tube by the power director.  However, I would find it hard to work through that small hole, it would be best to split the tractor maybe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote willard Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 8:44am
Thank you for the reply. I will rty through the right side panel. Hope my fat fingers can fit in the space.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2010 at 9:13am
Willard, your roll pin is sheared. Going to be a problem just to get it out. And you won't be able to get a new pin in, or at least I couldn't get it in when I had to do it. So I grabbed a shearpin (bolt and lock nut) for the 273 New Holland baler and tightened that in there and never has caused a problem since.
