rear hyd. D15 Ser.2
bcraigdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcraigdog Quote  Post ReplyReply Direct Link To This Post Topic: rear hyd. D15 Ser.2
    Posted: 23 Nov 2016 at 7:13pm
 REAR HYDRAULICS, D 15 SERIES 2
I have a valve mounted just above the differential, under the seat on the more left side with an adjustment knob on the rear of the valve. Is this a pressure reg. valve of sorts? Or what is it's function? It seems to do nothing. If you can't tell already, my first Allis. Appreciate any answers or help. Like to get to know everyone mods,etc. Thanks a lot and hope I get to meet ya.
Edited by bcraigdog - 23 Nov 2016 at 9:00pm
BCraig_Dog....."With ten miles behind me and ten thousand more to go. (James Taylor)
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 7:31pm
I'm gonna take a guess and say it's a transport valve. It was used when you have a mounted plow with a hydraulic cylinder on the tail. I never had one or used one, so somebody else may correct me on this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 8:22pm
Yep, transport valve, not for adjustment, for locking the remote cyl up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcraigdog Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 8:31pm
this valve is actually hooked up to a steel line going into the trans??? and one up to the pump housing? Suction and return? That's it, those are the only two ports on it. So is it sposed to control an external cylinder.......??? I have hunted for a picture but have had no luckSmile
Edited by bcraigdog - 23 Nov 2016 at 9:25pm
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 8:41pm
It's called the transport valve. When turned all the way in one direction it allows the lift arms to raise fully before oil goes to the remote ram on the semi mounted implement. Has to do this for traction booster to work. All the way the other direction it's as if it's not there. Lift arms or remote cylinder both get oil and whatever has the lower load will raise first.   This is used for fully mounted or pull type implements. It should be adjusted either fully in one direction or the other.
Edited by DanD - 24 Nov 2016 at 11:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcraigdog Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 8:56pm
Bear with me now.....hehe......where does the remote or attachment cylinder get its supply, as there are no more ports?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 8:59pm
If it is like mine, there is a removable plug on it where a remote outlet could be installed.  Just above the knob.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcraigdog Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 9:19pm
Ok, I got ya. I'll look at that thing a little better tomorrow! I am assuming the pump has a pressure regulator somewhere, (on it?) that's what I have been wondering.  I just bought this 1965, one because I needed it and two I think........I got a good buy on it ($1900.00) with the front loader and a 6' box blade. She runs very well and has good rubber. Thanks again for all your help. 🍺🍻πŸ₯ƒπŸ₯‚πŸΉπŸΊπŸ· <------  may have had one to many of them
ctbowles 58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles 58 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 9:39pm
It was used with a semi-mtd plow etc. you had to have the Transport valve to make the TRACTION BOOSTER work the way it should, if you don't have it with a semi-mtd plow the rear of the plow would lift before the front when the TRACTION BOOSTER was activated.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 9:51pm
DadD has it right along with Ctbowles58.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcraigdog Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 9:56pm
Edited by bcraigdog - 23 Nov 2016 at 10:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcraigdog Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 9:58pm
ok ctbowels, now that's what I want to know about. I Think.....hehe
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 6:30am
Single remote, for single acting cyl.  Power up, gravity down...
This page was generated in 0.139 seconds.
