Gleaner F shoe binding? Help
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F shoe binding? Help
    Posted: 14 Sep 2016 at 8:41am
Yesterday I had chain issues with the drive to the cleaning shoe. Got a new chain on and that's OK now. Harvested a few loads.But now the bearing popped out of its flange on the "cam". The part that turns rotation into a back and forth motion. I can't figure out what is going on. One side is fine its the "drivers side" that is causing trouble.
I'm hesitant to just put a new bearing flange on if there is some other issue? The bearing is fine. It seems there is some binding in the shoe itself causing stress on the drive.
Nothing in the manual on servicing the shoe. Should I grease the rubber bushings?
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 8:58am
When did you CHANGE all of the rubber bushings? I have seen the shoe bind with worn bushings. Also check the eccentric drive shaft being twisted, also if I member,there are woodruff keys on the shaft and they might be worn or sheared off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 9:26am
bushings are tight have to fight the arms off
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 12:00pm
Figured it out the bearing failed with the chain. New bearing new chain and some grinding on the sprocket and its working for now
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 6:57pm
pm sent'
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 9:14pm
   I saw you out in the field around !:00 today. To busy to stop, maybe tomorrow.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
